Results 1 to 20 of 20
Thread: New Pump
    Jun 2015
    Baldwin, Maryland
    146
    New Pump
    Good day all, I feel like Iv'e done enough reading over the past few days to ask some questions. Please if you could steer me in the right direction I would appreciate it.
    I'm interested in a new pool pump. I love my pool, but the one thing I dread every year is the electric bill going up. As it stands, I have a Hayward Power Flo Matrix 1.5HP pump. It's way overkill (At least I found that out after reading this forum!). All hand me down equipment. I turn it on for 4-5 hours a day and hate it. I can feel my meter spin. After everything it's $.142/KW here. I live in Maryland and right now we have a $400 rebate from the utility company if we get a VS pump, or $150 rebate for a 2 speed. I've been looking at the Pentair 342001 VS Pump 1.5HP. I just want to make sure this would be a good move. Does anybody have any downsides to VS pumps? I would go with a 2 speed to save money, but with the rebate it's a no brainer. I have a business acquaintance that's a certified electrician and plan to at least have him vouch for the work for the 3 year warranty. I also plan to house the pump in some kind of enclosure to prevent the elements from getting to it (I don't want the Pentair one, that looks flimsy, anyone have any DIY links I'd appreciate it).
    If you look in my sig you'll see my equipment. I don't know what to expect the RPM's/wattage to need to be at to go through the pool heater. Pentair states for my model heater it requires minimum 40/GPM. The pool heater will have a bypass, so when I'm not heating, no water needs to go that route (hopefully save the heat exchanger in the long run.)
    For me, $650 on a pump will be more than I've invested in the whole pool (not including electricity). I just want to make sure this is a wise investment and I'm on the right track.
    P.S. - To all those that have contributed to this forum, thank you. My pool has (mostly) stayed clear, and been easier to maintain than I ever imagined because of you. The wife and kids don't know it, as I'll admit I take full credit, but it's because of you!
    13.6K AG (I think?) 32'x16' Oval, Pentair SM8150 cartridge, Pentair SR400LP, Hayward Power Flo Matrix 1.5HP pump, Installed spring 2014 (hand me down, 4 years old when acquired), TF-100 Pool water test kit w/speed stir, Intex SWG (going since 2014), Well Water used for fill/top off
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: New Pump
    That is a great pump for your pool, you will save lots of money on the electric bill.
    You will be able to dial in whatever speed you need to keep the SWG happy and the heater happy, then you can set one of the preset speeds for that speed. Mine is 1 for SWG, 2 for solar panels, etc. I run my VS pump at 1100 rpm for skimming and making chlorine and it uses 150 watts. It runs at 1950 rpm for solar and uses between 550-600 watts. Which is considerably less than what your pump uses now. At 10.25c/kWh i can run my pump at 1100rpm 24x7 for less than 12 bucks a month.
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    WOW, that's awesome. That would be well worth it for $12/month + propane@.62/gallon to heat and run the pool.
    Now I'm a bit confused. Which one would last longer. I see they have differences between Pentair SuperFlo 342001 and Pentair IntelliFlo 011018 (I know it's 3HP, but the 1 HP 011008 is more $ for some reason.)
    I guess this is the IntelliFlo vs SuperFlo? I see IntelliFlo has more steps down, but would it be worth it to get for another $200??? Is it built better? I'm ok spending $ for something that lasts longer or is better built...
    Jul 2015
    Central Valley CA
    1,109
    Re: New Pump
    VS pumps are more sensitive to surges might want to install a surge protector while you are at it, the $40 to $80 for a protector is cheep insurance.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    DFW, TX
    24,513
    Re: New Pump
    The Intelliflo has more complex onboard electronics with more capability to interface with Pentair's pool automation like the Easytouch or Intellitouch. If you aren't planning to add automation then the Superflo will be a great pump for you.
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    Quote Originally Posted by atttech-2 View Post
    I did see that was an option, thank you.
    Quote Originally Posted by pooldv View Post
    Do you get more steps with the IntellFlo vs SuperFlo? I am my own automation, for better or worse, turn some valves....
    It sounds like SuperFlo I think. It's hard to sell it to the wife just yet with 3" of snow on the ground from last night.
    DFW, TX
    24,513
    Re: New Pump
    Dang snow! Not sure what you mean by steps. They are both infinitely adjustable in 5 rpm increments. You get 3 programmable presets with the SuperFlo and 8 presets with the IntelliFlo. Both will tell you how many watts you are using at the current speed setting. More here, including manuals, etc.
    http://www.pentairpool.com/products/...d-pump-464.htm
    Here is where I would buy it from,
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    Awww.... that makes much more sense. From what I was reading (it may have been referencing the pre programmed sets) there was only so many sets of RPM's to choose from. If I can go in increments of 5 RPM I'm sold.
    I did see that site, I saw it on Ebay for $644, but I'd rather get it at a reputable supplier such as you suggested.
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    If I buy from there I have to pay an additional $50 in taxes. (darn taxes...)
    I don't if I buy from Pentair Superflo vs 1 5HP Variable Speed Pool Pump Newest Model 342000 342001 | eBay
    It's from "backyardpoolsuperstore" and they have good reviews. Any input on this option?
    Edit: Nevermind, looks like they are selling the older 342000 instead of the 342001
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Re: New Pump
    Just my 2 cents....VS is the way to go. I went with the 2 speed Pentair. Nice pump but the energy savings are much better with the VS as the experts have already mentioned above.
    47k, 40x20 IG plaster,SWG, 24 jets, 3HP Pentair Whisperflo 2 speed,Hayward Pro Series Sand Filter36" Tank S360T2 TF-100
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    Quote Originally Posted by Jaxcmc View Post
    Every 2 cents helps. I'm sold on the Pentair VS 342001. I will purchase from Sunplay as mentioned above. $700 total after taxes with $400 rebate (probably credit) from utility company ~ $300. As long as I take care of it, surge protection, some type of enclosure, 3 year warranty with qualified install, should be ok. This will be my biggest investment on the pool yet.
    DFW, TX
    24,513
    Re: New Pump
    I don't think I pay any tax with them. Give them a call. They are great folks with a real store in Utah. I buy pretty much everything from them.
    BTW, on the 3 presets on the Superflo, you can set them to whatever speed you want. They come preset but you can change them.
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    So....I did call, thank goodness I did. They said they are having issues with their website adding tax and that the only people that have to pay tax are residents of Utah. She said when I get to the end the tax would be removed. I'd much rather deal with a company that's well known like them anyways.
    I did read more of the manual, it was a little confusing without hands on, but I get it now
    3 presets would be skim > heater > cleaning
    Do most people just run it on low 24/7 or cycle on and off?
    Should be ordering within a week or 2, I just like to do my homework first.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: New Pump
    Mine came with fittings also, I think the inteliflow you have to buy seperate
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: New Pump
    Here is the surge protector that I added to the panel feeding my pump. Cheap insurance at only $25.
    Amazon.com: Square D by Schneider Electric SDSA1175 Panel Mounted Single Phase Type 1 Surge Protective Device: Home Improvement
    chiefwej
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    Quote Originally Posted by chiefwej View Post
    Great find!
    DFW, TX
    24,513
    Re: New Pump
    Good news! I leave mine on 24x7 in spring and fall because we have lots of trees dropping stuff in the pool and it is better to skim that stuff before it sinks to the bottom. I vary with the other times. It runs quite a bit in summer for solar heating and not much in winter. It is so cheap to run it doesn't really matter a lot!
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    You guys, this has been a great help. I really appreciate everyone's responses. Thanks.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: New Pump
    I agree. The Pentair Intelliflo VS offers the most flexibility and energy savings options that you're looking for. Get that rebate!
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
  20. Back To Top    #20
    Jun 2015
    Baldwin, Maryland
    146
    Re: New Pump
    Quote Originally Posted by Frankhugus View Post
    I'm going for the Pentair SuperFlo VS 342001. It is variable speed and $650. I don't need all the bells and whistles the IntelliFlo has or the 3HP.
