Results 1 to 14 of 14
Thread: Slam Time!1
    Sep 2015
    Humble, TX
    26
    Slam Time!1
    So been following now for over a year and made the switch at the end of the season last year (End of Sep). With the pucks all last summer I had several algae breakouts and ended up with my CYA levels over 120. So six months later with just bleach and standard evaporation and kids splashing I had added water and got my CYA down to 70 (I know it needs to be lower and by mid summer should be there with out a draining of any sorts) and ready to slam to get the pool ready to go for summer.
    Pre Slam Readings:
    FC-7.5
    CC-0.5
    CH-250
    TA-130
    PH-7.8
    CYA-70
    I added Acid (brushed) and got my PH to a about 7.0-7.1 before adding bleach. I took it a bit lower then 7.2 because I have a 7 foot spill way from hot tub to pool and with this my PH climbs rapidly when the pull runs.
    SO I have added 8 gallons of bleach (brushed) and will test lvls to see if I need more to hit my FC of 28 (which I should). Questions I have are the Polaris, does it need to be removed during the slam or should I let it run off and on to pick stuff off the bottom? It is fairly windy here and pines are dropping stuff in pool like crazy. Second question is pollen, it is everywhere, what affect will this have on my slam, will it constantly eat my bleach?
    Oh yea test kit is a TF-100
    Thanks in advance for the pointers and advice?
    Inground 30,000 gallon Chlorine Pool/Spa with a Pebble Sheen
    Finish Hayward Omni Logic Wireless Controls
    Hayward 3HP VSP, Hayward 1.5 HP pump Waterfall, Hayward 1.5 HP Booster Pump
    Haward 400,000 BTU Heater, Hayward Cartridge filter,
    Polaris 280 Automatic cleaner
    Jun 2014
    15,008
    Re: Slam Time!1
    Although not necessary, you're fine with the Polaris. Pollen is not big deal. Let your skimmer (or skimmer sock) collect as normal. Stay on that FC and you'll be fine. You've probably heard the song ... "Maintain, maintain, maintain".
    Sep 2015
    Humble, TX
    26
    Re: Slam Time!1
    Ok so I did something wrong already
    When I plugged in the calculator I put the wrong % chlorine, so instead of 28 im closer to 48. I should have added close to 7 gallons I added eight so not sure how it jumped so high
    Not sure how the heck I have done this but any advice? I have tested three times and getting same result every time.
    Im going to let it run over night and recheck in the morning.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Slam Time!1
    I would just let it work. It will most likely take several days for the FC to drop. Keep brushing.
    Jun 2014
    15,008
    Re: Slam Time!1
    Grab your dirty whites and throw them in. No sweat. It will drop on its own soon enough. Watch it tomorrow and adjust accordingly. Double-check your pool size and % in the calculator, to include your NOW and TARGET values. Mistakes happen. This isn't the worse. If you continue to have problems, let us know.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,421
    Re: Slam Time!1
    Been there, done that! NO big deal. The algae will help take it down. Just NO swimming while you wash your whites in the pool! LOL
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Slam Time!1
    No worries Badag, it will actually help.
    Essential Links:
    Sep 2015
    Humble, TX
    26
    Re: Slam Time!1
    Reading this morning was down to 46! (lots of drops good thing I have a new refill waiting to be used)
    Question on the PH, I remember reading that you get false readings with High FC, I tested anyways and yes it shows 7.8. My concern is I know that my PH rises rapidly anyway due to large spill way, and I add around 6 oz of acid almost daily to keep it below 7.8. Should I keep my routine of adding acid during this process or is there a way to get a true reading on the PH?
    Sep 2015
    Humble, TX
    26
    Re: Slam Time!1
    So last reading before bed last night FC was at 35 and CC was at 1, first reading this morning FC was at 33.5 and CC was at .5. Getting there I guess?
    Anyone with comments on the adding acid during the slam process my PH looks to be in excess of 7.8 with the skewed test but I know it is rising with the pool running.
    Jun 2014
    15,008
    Re: Slam Time!1
    It does sound as though you are on the right track. Good work on that FC. Generally we just ignore the pH during this time period. If the SLAM was to continue for a long period of time and we had a strong concern about the pH, you could let the FC come down below 10 just long enough to re-validate, but for now I'd say leave it alone. We really don't want to interrupt the progress you're making on the SLAM. Stay on it, and great work.
    Sep 2015
    Humble, TX
    26
    Re: Slam Time!1
    Noon Reading today FC down to 31.5 and CC 0!! Almost there!
    Jul 2012
    Tallahassee, FL
    30,421
    Re: Slam Time!1
    How is it looking?
    Kim
    Sep 2015
    Humble, TX
    26
    Re: Slam Time!1
    So reading this morning is 29 so I have passed the overnight test! Water is clear I can see the screw heads on the drains and passed this test so im calling it good.
    Plan is to put in new filters later today, do I need to keep the pump running till the FC lvls drop back to normal or just run the pool on my normal schedule?
    Jun 2014
    15,008
    Re: Slam Time!1
    Alright! Passed OCLT, less than .5 CC, and clear water. Once that FC sinks below 10, you can check/adjust pH. Yes, resume normal operating schedule. From now on, just make sure you maintain your target FC based on your CYA and you'll be fine.
