Thread: Light Placement Question
    Feb 2016
    Atlanta, GA
    145
    Question Light Placement Question
    Attachment 45484
    I am in the early planning stages still.
    I was thinking 3 jandy 30watt white led nicheless lights evenly spaced apart at the same depth. One installed above the last step.
    Also 1 9w lighting up the tanning ledge.
    My question: Do you think that is enough power? Is the placement okay or should there be one on each end and one in the middle?
    I haven't seen too many nicheless lights in build threads so I don't really know their brightness.
    Thanks
    -Ryan
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Light Placement Question
    That is good if it is facing away from the house. The idea with lighting is not to have it facing the house, primary seating areas or into swimming lanes if you plan to swim laps.
    Jun 2014
    15,292
    I can vouch for the swimming part. Some friends broke one of our LED covers last season while horsing around. Seems like anything that could used as a step or leverage during a ferocious battle of volleyball becomes target for feet and stepping upon. BTW, I have 3 LEDs along my 40' pool and it works very nice.
    Feb 2016
    Atlanta, GA
    145
    Thanks for the input!
    They are facing away from the house. That makes sense - if you are swimming a lap you wouldn't want to be blinded by light pointed head on.
    Texas Splash: Nice pool! - what led's did you go with?
    -Ryan
    Jun 2014
    15,292
    Ahhhh, you would ask that question. I need to dig in my papers or look tomorrow when it's light out. I'll get back with you.
    Looks like mine were called PAL Rainbow LED lights - 3" I believe.
