Results 1 to 16 of 16
Thread: Owner build in Gilbert AZ
    Jan 2016
    Gilbert
    4
    Hi Everyone,
    Typical story, been lurking for a bit and now it's time to break dirt. Attached is our preliminary design. Pool is going to be for a boring husband and wife, 2 teenagers, and 3 dogs.
    Looking to put in a grotto without a slide and have the pool 8 feet deep around the grotto.
    2 led lit bubblers on the baja deck.
    Should we have 1 or 2 led rgb lights for the pool?
    Also what type of decking? We are looking at Artistic Pavers products. Any pros or cons? Main reason is price although we certainly like the look.
    Welcome any and all comments and will post pics when we get this project moving. Screen Shot 2016-03-03 at 4.06.10 PM.jpg
    Aug 2014
    Northern IL
    4,615
    Re: Owner build in Gilbert AZ
    Bump
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Welcome to TFP!
    I'm sure the experts will be along to answer your questions and give you great advice!
    I'm having 3 lights in my pool and one in my spa
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Apr 2013
    Sacramento, CA
    2,769
    You need 2 lights in the pool. Both on the house side so they face away from the seating. They shouldn't face directly into the groto.
    Nit a clue on pavers
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,544
    Paver=Depends (sorry) you have to ask your local permit department. They are all so different. Let us know what they say.
    I like the 8ft off the grotto. Just make sure the grotto is built for standing on and jumping off of because you and I both KNOW the teens WILL do it! LOL
    I would think about another bench in the deep end. Those seem to be neat and well used handing out areas in pools.
    Kim
    Mar 2016
    Peoria, Arizona
    3
    Sorry totally off topic but we are going the OB route on the west side and I was wondering who did your designing and engineering? We are just starting out and trying to decide who to use let alone having a hard time finding anyone.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Welcome and congrats on making the decision! First off, was it you that decided that your DH is boring? Or is that a mutual thing? No need to reply!
    A few thoughts...
    The picture is too small for me to read some of the details, if you can post it larger that might be helpful for the discussion.
    It looks like there might only be one skimmer, and if that's a 36' length, two might be more appropriate. Especially with all those curves on the outside to distract the water from flowing to your skimmer. They are best located downwind, which can often be more than one direction based on time of year, etc. I'm not crazy about looking at them so I'd put one on the lower left and one on the lower right if all else being equal.
    Lights - one LED will not be bright enough. You will want two plus the bubblers. It's kind of tough for you to place them optimally since the grotto and the primary seating area are basically opposite each other. I'd opt for roughly underneath of both skimmer locations suggested above. Grottos also look awesome with built in lighting. There are several builds here that show this to great effect.
    Agree with the deep-end bench suggestion (maybe even a standing height bench) on the left and maybe one opposite the planter. It's almost impossible to have to much bench space.
    I'd also recommend posting up your intended equipment specs and plumbing details. These are important aspects to the overall healthy/efficient operation of your investment - and many times overlooked in favor of layout/design.
    Travertine seems to be the best (or possible individually most popular) deck choice for warm climates for the pretty factor and coolness under foot...thought at the expense of, well, expense.
    Oh, and 3 dogs, definitely two skimmers, at least. More time between hair nets getting clogged!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jan 2016
    Gilbert
    4
    Actually I'm a self diagnosed boring DH. That's me. (As an aside what does the D in DH stand for? Never figured that out.)
    Don't know how to make the picture bigger. Should I do links to another service? I just used the forums uploader for the diagram I have.
    You'll find that I kind of am jumping off the deep end with this project. (Sorry, couldn't resist.). So I appreciate any and all info. Don't have a clue about what filter, pump(s) etc. . . just figure I'll learn about it as I go.
    For systems I know there is hayward and pentair. I'm leaning with pentair as the bigger builders here use them and they seem to have the better automation. As for filter DE, cartridge, or sand. Well. . . like I said, I'm figuring it out as I go. What does the collective wisdom say to use? 2 of the dogs won't be swimming the other is a short hair.
    How about pumps? Should I go with 2 or 1? I was told I am good with 1 so long as I don't mind walking over and switching valves at the same time I realize that after a few beers that journey looks further and further.
    Pretty much sold on 2 led lights. Want to imbed some inside the grotto as well.
    The two skimmer idea seems like a good one as well.
    Thanks for the info and I'll be posting pics as we get going. Right now nothing to show but a desert moonscape as there is absolutely nothing in our backyard yet. We just moved into a new build.
    Jul 2012
    Tallahassee, FL
    30,544
    Several use photo bucket for pics.
    Lol for the pun good one!
    Kim
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    I think the 'D' stands for 'Dear'. Lol.
    Can't wait to see how it progresses!
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Jul 2014
    Las Vegas Nevada
    27
    Hi there! I sent you a pm regarding Artistic pavers.
    Apr 2013
    Sacramento, CA
    2,769
    A single 2 speed or vs pump will be fine. With pool automation you control the pool from your lounge chair ( even if the lounge chair is in bora bora with some systems) so one pump is fine.
    You need to be deciding about you grotto now. What is it going to look like. Because that is something you are going to have to explain to the engineer who will engineer it and the steel crew and the gunite crew.
    The engineer will also charge you extra for the grotto.
    Jan 2016
    Gilbert
    4
    Thanks for the PM. I appreciate it.
    Just replied.
    gwegan: Thanks for the info on the pump. I'm guessing that is what actuators do? Turn the valves based upon what I want? Just got an Amazon Echo and I love that. Never knew I was so lazy, can turn my house lights on and off and even dim the lights with it. Would love a way I could hook my pool stuff up to the Echo.
    What HP would you suggest on the pump. Just this morning someone said 3 hp makes no sense with 2" pipes. This threw me off as the PB's have all been pushing the 3 hp variable.
    Just experienced the upcharge for engineering a grotto. Went from $60 to $360. Oh well. The grotto and depth is for the kids, that's already an addon of a few thousand. $300 more is a drop in the pool.
    Once again, thanks for the info everyone.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    The Pentair 011018 3hp variable speed pump is one of the most popular and most energy efficient pumps on the market currently. Many folks on TFP have them and love them, including me. It is important to use the same brand pump, SWG and automation to make sure everything will work well together.
    Pentair IntelliFlo Variable Speed Pump 011018 | Pentair 011018
    Apr 2013
    Sacramento, CA
    2,769
    You want the lowest hp that will serve your pool. I would suggest 1.5 or 2 hp pump. The only water feature you have is the bubblers. If you were to add solar or a waterfall I might have a different opinion but for what you have a 1.5 to 2 hp pump will be fine.
    DFW, TX
    24,497
    That is a good point. Here is an excellent 1-1/2hp VS pump. It will have a little less functionality if you use pool automation but it is a grea, energy efficient pump.
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
