Thread: A few issues hooking everything up
    May 2008
    Southern Connecticut
    56
    We filled the pool to the right level today and now there is a few leaks. One leak is where the backwash port is. The pool filter was on closed and water is dripping out of it. Also sand is coming out when we put it on backwash. The other leak is where the filter hose connects to the pump. We tried to tighten it but the water is dripping out. We haven't turn on the pump yet.
    You can see the water coming up
    the water is dripping out of the lid
    water dripping out of backwash
    18' Willow round AG 52", 19" Sand filter 1 hp pump, Intex SWG 8110, Bought and install May 08
    New 12'x16' deck built March 09
    Poss thinking about solar panels next!
    30,432
    Re: A few issues hooking everything up
    You might be missing some o-rings.
    Check to see if there's a rubber o-ring in your pump basket where the lid goes on. There should also be one in that half-union that connects the pump to the top hose.
    The backwash line is coming off what's called the multi-port valve. (You should have a hose connected to that backwash port to carry off the backwash water) The multi-port valve has what is called a spider gasket on the inside to prevent leaking. If yours is just dri[pping, I'd leave it alone. If it's leaking more than you can stand, you'll need to disassemble the multiport valve and replace the spider gasket.
