Results 1 to 7 of 7
Thread: Is it time for a clarifier?
    Feb 2016
    Los Angeles, CA
    37
    So for the last few weeks I've had a problem with a lot tiny debris just floating around the surface of my pool. And I can't seem to get rid of it.
    I've cleaned my filter. I added the right amount of DE. I run it for 8 hours a day. I skim. I brush. I even have a thigh high sock on my skimmer basket.
    The water is crystal clear except the surface.
    My levels are:
    FC 4
    pH 7.4
    TA 90
    CH 300
    CYA I added CYA on Saturday so I'm waiting a few days to get a proper read
    What else can I do to get rid of this dirt on the surface?
    22,000 gallon in ground pool with pebble finish. Pentair DE filter with Pentair VS pump. Built in the 70s but completely redone (including new pebble finish, equipment, and plumbing) in August 2015. K-2006.
    Donldson's Avatar
    NW Ohio
    2,892
    Re: Is it time for a clarifier?
    A clarifier won't do anything for this, this looks like typical organic debris falling on your pool faster than the skimmer can filter it. My best advice is to make sure that your water level is at the right height for your skimmer (you should see a distinct flow of water over the weir door) and possibly increase your pump run time. If you have a main drain you might try closing it to see if that helps get more suction to the skimmer.
    Again, a clarifier is rarely needed in the first place and won't help at all in a situation like this. The stuff floating on the top (looks like a fluffy seed, much like the cottonwood seeds I will deal with here in a couple months) has to be physically removed, either by you or the skimmer.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    JoyfulNoise's Avatar
    May 2015
    13,198
    If you are using using a leaf rake on the surface of the pool to clean up leaves, you could try buying a finer mesh bag for it. The even sell very fine nylon mesh for it, similar to what you would use as a skimmer sock. You then skim the surface with your pole skimmer to remove all the big debris and then, very, very slowly, you use the finer mesh bag to capture the pollen/dust that sits on the surface (you need to go very slowly so as to not create waves that will push the debris away from the skimmer bag).
    Sorry, I know it's frustrating but anyone that lives in an area with any significant vegetation tends to get this kind of stuff floating on the surface. There's really no way to get rid of it easily and anything you try chemically will likely cause you more chemical problems than actually solve the debris issue.
    Matt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    What they said. Plus, experiment a little with redirecting the return eyeballs to see if you can improve the surface flow.
    30,416
    What is your pump run time? Think about increasing it if it's less than say 10 hours.
    Feb 2016
    Los Angeles, CA
    37
    Thanks for the responses. I'm going to try a silt leaf rake. I had no idea that was even a thing. I just ordered one through Amazon. I'll update if it doesn't do the trick, but I have high hopes it will work.
    Aug 2014
    Shallotte, NC
    693
    A skimmer sock will help, too..... It is that time of year and you just have to deal with it! A closer eye on filter pressure may be in order, too..... it will get clogged quicker.
