Thread: Air is getting in, but how
    Mar 2016
    Titusville, FL
    2
    I bought my brother's house in early December. After turning the pool from a swamp green to a pretty blue, we added a barracuda g3 to help keep it clean. Since our pool is not screened and we get a lot of leaves from neighbors trees and sand because it's really sandy here in Florida, we also have an in line leaf catcher. After running it a day, it must be cleaned or it will cause not enough pressure due to a lack of suction. Now I know, I just empty it. No problem there. Pain, yes. Now for the problem.
    It now has air bubbles flowing through the system. I haven't run the cleaner in a couple of weeks because of it. You can hear them in the lines and the filter and the clear part on the pump near the filter has too many little ones (not a big bubble like when pressure is high from algae gases when you're trying to flip it back to blue). The pump is running barely at pressure. I tried releasing air on the filter with the release valve and it shoots water. Just before the bubbles entered and became troublesome, I had had the cleaner out for a few days and the skimmer had been full of leaves. I asked hubby to empty it and it didn't get seated back in correctly. The pressure was really low on the filter and I noticed that there was a plastic plant pot blocking the skimmer and the basket was on its side full of debris (it had been extra windy and blew all kinds of debris into the pool). Now the bubbles just won't stop. Any ideas on what's causing them to get into the system and not go away? Am I hurting anything by running the pump/filter each day with the bubbles? Pressure is just at the green mark. It does the usual blowing the bubbles out of the system at start up, but then the sound is still there and you can see some. Good flow on the pool jets.
    Thanks in advance!
    Inground, early 1980s plaster I think, no idea the volume, almost 8' deep end, almost a rounded cross shape that's 10'ish across narrowest and about 16'ish at widest, missing some top edge tiles well above water line but she's a beautiful shade of blue...my beautiful disaster.
    Hayward EC65A DE filter is approx. 2-3 years old; auto chlorinator
    Jul 2015
    Tempe, AZ
    194
    Re: Air is getting in, but how
    When my system got really clogged up with leaves and debris a few weeks ago I was getting some tiny bubbles coming out the returns. The basket at the pump had filled with enough debris that it was really limiting the flow on the vacuum side of the pump. I believe this was causing the pump to draw air either thru the seals or by some gasket. As soon as I cleaned everything out, no more bubbles.
    Any chance you still have something clogging up the vacuum side of things?
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    It sounds like a suction side air leak. Make sure your pump basket has been cleaned and sealed correctly. Use pool silicone on the seal. Not Vaseline
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mar 2016
    Titusville, FL
    2
    Thanks for the suggestions! I'll try re-cleaning the pump basket and using some of the "Waterproof Lube Tube with PTFE" from the pool store on the seal. I already use it every so often, but maybe I need to use it more frequently. I'll clean the filter basket again and add more of this to seal, unless you think I should try something different on it.
    If it's still doing the same thing, I'll figure out how to see if there is any blockage in the line (nothing is visible).
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,448
    Can you send us a picture of your equipment pad showing the pump and any valves on the input to the pump? Also, where does your bac-a-rooda connect?
    When is the last time the filter was cleaned? Does your pressure cage have numbers, if so, what pressure is "green"?
    How many skimmers do you have?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Another thought, is your water level where it needs to be in the pool...half way up the skimmer?
    Montgomery, AL
