Thread: Dimmer switch
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Dimmer switch
    Is there any reason a pool light can't be on a dimmer switch? I have a color changing LED that is on a standard switch.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Apr 2013
    Sacramento, CA
    2,769
    Re: Dimmer switch
    I do not believe any of the LED lights sold for pools are dimable. So the short answer is no it won't work.
    Only some LEDs are dimable. And they each require a specific switch to work properly. Some switches work with some, some with others. But I'm unaware of any LED pool lights that dim.
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Dimmer switch
    Yeah, current LEDs and dimmer switches rarely get along well. Even the dimmable ones are hit-and-miss overall.
    The problem lies in where the switch is located. LEDs are run by DC, while the power coming to them is AC. So there is circuitry built in to rectify the AC to DC. LEDs are actually very easy to dim, lower the voltage and they emit less light. But that is on the DC side and the dimmer switch is on the AC side, and typical rectifier circuits are designed with a single voltage in mind (110-130 volts in the US). Messing with that voltage will usually just turn off the light.
    Your best bet would be to see if you can find a remote controlled color changing LED that will fit your current fixture and then you can dim it remotely.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Dimmer switch
    Thank you both, I'm glad I asked first.
