Results 1 to 10 of 10
Thread: Do Intex sand filter pumps come with plungers and large inlets/ strainers?
    Mar 2016
    Wantagh, NY
    31
    Greeting, first time poster. Thanks to this forum and a lot of great ideas, I am excited to update my Intex 14X42 Ultra frame pool this summer with a Hayward Skimmer and Intex sand filter pump.
    I think I a have settled on a 2150 GPH pump for my needs , but there seems to be some confusion as to what accessories these pumps come with. I have seen different models of what looks like the same pump, Model 28647EG, and SF 70110 seem to be the same, some reviews say it comes with the plungers and larger inlets, some don't.
    Can someone tell me if these pumps do come with accessories , or is there a certain model number I should be looking at?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Do Intex sand filter pumps come with plungers and large inlets/ strainers?
    Welcome to TFP!
    Glad to hear you are excited about some nifty pool upgrades! Have fun!
    Hopefully someone with one of these filters will be along soon to answer your question.
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    My next door neighbor has a Intex pool. He originally had the cartridge filter which did NOT have the plunger valves installed. He purchased a "Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2800 GPH Pump Flow Rate, 110-120V with GFCI" off Amazon which he had me install. It did NOT come with the plunger valves or larger inlets. It also didn't come with the needed Type B adapters which allow you to hook the larger hose to the smaller ports on the pool. He ordered the Type B adapters and I installed the new pump/filter withOUT the plunger valves using the Type B adapters.
    I still have no clue wth they are for.
    Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2800 GPH Pump Flow Rate, 110-120V with GFCI Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2800 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Mar 2016
    Wantagh, NY
    31
    Thanks, I think the Plunger valves just close off flow into the hoses, but I really do not need them since I plan on hard piping my set up with regular gate valves.
    As far as the B adaptors, I read I might need those special "box" adaptors to hook up the PVC pipe to the B adaptors, correct?
    Jun 2014
    15,059
    Many, many folks have done such upgrades. While waiting for more owner-specific replies, perhaps these two examples will help if you haven't seen them already:
    INTEX pool with PVC plumbing - YouTube
    Intex Pool Upgraded Hard Plumb, Pool pump, Sand Filter, and Salt Water Generator - YouTube
    May 2015
    Wichita KS
    29
    I just bought this exact pump (received yesterday) from Amazon and it did NOT come with the plungers.
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    DFW, TX
    24,483
    Thanks for chiming in rdy2fly! Nice first post!
    Mar 2016
    Wantagh, NY
    31
    Thanks for the you tube link. Wondering why in the first video I do not see a skimmer?
    Also speaking of Skimmers, I will cut in a Hayward skimmer this year. I have a question as to how high can you mount this on the pool wall?
    Reason I ask is that if you look at my pic on top, the concrete is sloped from right to left, away from my house. So there is approx. a 2 " diff in water level.
    I am putting filter and pump on deep end on the upper left of the picture by fence. If it's true that I can only fill water halfway up skimmer and loose a few inches water, it will be greatly exaggerated on the shallow end. So my options are mounting skimmer on shallow end opposite of the pump ( which I did not want to do) or mount skimmer high up on deep end. Can gasket be put above grey part of liner where stitching is? ( above the squares) Or can I fill water to top skimmer so I can keep same depth of water?
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I kept my skimmer below the seam because I was concerned about not getting a watertight seal if I went over the seam with the gasket.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Mar 2016
    Leonard, Tx
    5
    We installed a sand filter on our pool a few days ago and it did not come with the plunger valves but it did come with the adapters needed. I had read it didn't come with the adapters so I ordered them and now have two sets.
    I too am trying to figure out a solution for a skimmer but do not want to cut one into the pool. May not have any other options but it won't happen this year. They do sell a cheap crappy looking wall mount one from intex that I thought would work in the mean time but the adapter to hook up to the inlet nozzle is too small to fit mine.
    24x52 Pro Series Ultra Frame Pool; Intex Krystal Clear Sand Filter Pump, 2100 GPH Pump Flow Rate, 110-120V with GFCI; Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O.
