Results 1 to 20 of 20
Thread: Two Different Fence Heights
    Mar 2013
    CT
    353
    Does anyone have a fence around their pool that has two different heights to it?
    We have a four foot chain link around our entire pool. We wanted to replace one run of the fence with a 8' white vinyl fence. I'm wondering if that would be too drastic of a transition??
    We'd like to replace the back portion of fence against the hill with the higher vinyl fence.
    Has anyone done this type of thing? If so, Id like to see some pictures.
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Two Different Fence Heights
    Haven't done it but I like it. Good plan!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I think it would look very nice! I say for for it! You can even pretty it up with cute decorations like flip flops signs and such!
    Kim
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    That will look nice and the black fence will barely be noticeable since they tend to disappear
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I think it all depends on where you want to put said white fence?
    One advantage of what you have now is that black chain link fencing appears to disappear from view (unlike bare metal chain link). So you will be cutting into the view with white solid fencing but....it still might look good.
    Have you considered putting trees back there instead?
    Mar 2013
    CT
    353
    I have but the cost of trees, given the number i need, is much higher than one wall of fencing. Plus they would take years to mature.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Just my two cents but try to buy the more expensive vinyl fencing as the cheaper HD fencing can look flimsy and, excuse the expression, a little on the trailer trash side. I know some ppl have gone vinyl thinking low maintainable, etc, and end up very much regretting not having gone with wood. Also, stay away from the panels that are made in sections as you have to replace the whole section if damage occurs to just one vinyl plank.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    wjr75's Avatar
    Jun 2013
    IL
    836
    You definitely need some blockage back there from the neighbors. My last house we put in some of the vinyl type fencing that looked like cedar and were happy with it. The stuff wasn't cheap and the wood version would be cheaper. I hate painting fences so that is why we went with it. You can put some bushes in front of it also to smooth the transition. That's what we had.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    DFW, TX
    24,514
    Lowes does have 3 new vinyl fences that are made to look more like real wood fences that seem pretty nice.
    Mar 2013
    CT
    353
    Im thinking of the fence w the lattice on the top just to break it uo a bit.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Honestly, both Lowes and Home Depots vinyl fencing are not quality fencing...they use three rails instead of two because the fence material is so thin. It looks good sitting in the shopping aisle racks but disappoint once installed. Lowes Freedom and Brighton fence lines are poorer quality than HD Arrowhead and their pricier Windham lines...(tho the HD lines are far superior than both the Lowes lines). Best to go with a non-big box store manufacturer via your local fence companies.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    If it were me, I would greenscape for privacy. Two layers of tree/hedge and a few Freestanding Acurio panels interspersed for privacy/artistic punch.
    Got CT, you should be able to get a number of upright arborvitae or juniper that can be hedged to 8'. You're correct that it will take one (maybe two) season to get full coverage but even the initial planting would make a difference.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Aug 2014
    Houston tx
    2,525
    ^^+1. Definitely use greenery for privacy. I'm not sure how a white vinyl fence would look.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mar 2013
    CT
    353
    Honestly arborvaites were my first thought. Im thinking of going that route. I just have to price things out. Obviously one wall of vinyl fencing would be alot cheaper...
    Jul 2015
    Fremont OH
    42
    Look at Green Giant arborvitaes. They get pretty big, so I'm not sure if there is enough space where you want to put these or not, but they grow very fast, and are very hardy. Deer resistant too. I planted some a few years ago, and they're literally growing 2-3 feet per year.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    I too believe a white fence will strongly detract from the attractiveness of the landscaping that is on your property and what can be seen in that respect on the adjacent property. The alternatives referred to above would look really nice,...but if a fence is in your future, a darker color stained 5-6 foot board fence with a 18"-24" lattice extension would be my first choice, followed by a dark vinyl fence of the same configuration. Both would give a more appealing natural look over the starkness of a tall white fence erected on just the one side of your property.
    Mar 2013
    CT
    353
    Thanks for all the input. After reading these posts and thinking about it some more we decided to go the arborvitae route. Green giants would be way too tall for that space - blocking out some late day sun which we most certainly dont want to do. We're looking at Emerald Greens which seem to be the best solution.
    'Emerald Green' Arborvitae is an ideal quick privacy fence. It keeps tight foliage, stays light green, and reaches a mature height of 12-feet. These characteristics make the tree a better option in some cases than the more commonly planted Thuja Green Giant. The Emerald Green is not damaged by snow, ice or deer. It is best planted three feet apart for an instant living fence.
    DFW, TX
    24,514
    Alright, that sounds like a good plan!
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by dschribs View Post
    I have some of those that we put in when the pool was built. I think they are a good choice over the green giants since the overall height will be limited, the negative is they do grow slower also. Ours were about 1 / 2 feet tall when they were put in approx 5 years ago, a couple are about 8' tall now and the others are about 6'. They are about 2' in diameter now, so the 3' spacing is good, I would stagger the row slightly.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
  20. Back To Top    #20
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I had 4 foot chain link fence with giant arborvitaes. It had already been there for years and works pretty well.
    The only downside being that there were some thin areas where people could see through and if a windy day
    ever happened I'd be filling wheel barrows full of dead arborvitaes leaves that had dumped into the pool.
    Not sure about where you live but a lot of areas require a permit if you exceed 6' when fence building.
    Dolphin E10 Cleaning Robot.
