Thread: Complexity of diy swg addition
    Feb 2015
    Austin, TX
    50
    About a year ago I was able to transform the pool that came with my house from swamp to summer fun using the great advice here (thanks!). Now that I know a bit more I would really like to switch to a SWG to avoid storing and carrying bleach on an almost daily basis. It seems like there are reasonably priced systems like the circupool that should be not to hard to self install. So my question is, what is involved exactly in the installation? Also can you have a look at the pumping station and comment whether you see any potential problems? Would it be a good idea to take out the puck chlorinator and insert the swg in its place?
    Thanks!
    IG plaster pools built in 1985 (?): 16k(?) gallons lap pool (62'x8') connected by a spillover to 17k(?) gallons squarish pool (22.5'x18'). DE filters Pentair NS-48(x2), polaris 280 (non-functioning). Inline chlorinator [removed!] -> Circupool Si60 SWCG [Newly self installed March 2016!]. Recently acquired dolphin nautilus+ [Summer 2015]. Still figuring out what else I have and how things work.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Complexity of diy swg addition
    Good job taking care of your pool! Yes, that is a good spot for an SWG, is that hose in front of it the suction for your pressure cleaner? There are quite a few happy Circupool SWG users on TFP. We typically recommend sizing an SWG at 1.5-3 times the pool gallons to avoid having to run the pump excessively to make enough chlorine. So a 60k swg will be ok. All you do is cut the plumbing line and solvent weld the unions for the cell. Mount the controller on your Uchannel and connect 2 hots and a ground wire to the switched side of your pump timer and connect the bonding wire to the bond loop.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree where the puck feeder is a likely a good place for the SWG, it is hard to tell how hard it will be to splice in from that photo with the pump outlet line blocking part of the view though. I don't recall hearing anything bad about the circupool, however it seems the most popular and most often recommended SWG's here are the Hayward units, as they seem to have some of the best bang for the buck on units and replacement cells if you buy online.
