Thread: Well this was a first
    Donldson's Avatar
    NW Ohio
    2,906
    Was walking through the pool supply aisle at Menards and saw this:
    Looks like they are getting a bit fancy with their CYA label.
    Edit: forgive the bad picture, was on a high shelf and I am a bit short. It says "Chlorine Stabilizer and Conditioner"
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2014
    Northern IL
    4,615
    Re: Well this was a first
    Good luck with that, Menard's! How many consumers know what the chemical composition of CYA is??? And I am afraid people may just buy it thinking it will improve their water. Oh! More new TFP members with high CYA levels. Oh dear...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Ok, I googled that.
    Triazine derivatives
    N- and C-substituted triazines are used industrially. The most common derivative of 1,3,5-triazine is 2,4,6-triamino-1,3,5-triazine, commonly known as melamine or cyanuramide. Another important derivative is 2,4,6-trihydroxy-1,3,5-triazine better known as cyanuric acid.
    I wonder why in the wide, wide world of sports they are calling it that instead.
