Results 1 to 10 of 10
Thread: PB says don't use Clorox!
    Nov 2015
    Humble
    101
    Says it will raise salt levels and cause scale?
    IG Gunite, 16' x 30', 3 1/2' - 5' deep, ~11K gal, Pebblesheen, Intelliflo VS pump, Clean and Clear 420 Filter, LED Color Lights, Taylor K2006 Test Kit.
    Build thread http://www.troublefreepool.com/threa...d-in-Humble-TX
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: PB says don't use Clorox!
    They all say that.
    1 gallon of bleach (8.25%) in 10,000 gallons of water will raise the salt level by 14ppm. But....
    32 oz (2 lbs or about four 8oz tabs) of trichlor will raise your salt by 18ppm in 10,000 gallons. And....
    32oz (2 lbs) of dichlor will raise your salt by 11ppm. And....
    128 oz of Muriatic acid (roughly 1 gallon of Hydrogen Chloride) will also raise your salt levels by approximately 20ppm.
    So, as you can see, EVERY chlorinating product you put in your pool raises your salt levels (chlorine becomes chloride).
    As for scale, hogwash! Bleach can temporarily raise your pH (if you put enormous quantities of it in the water all at once) but the pH rise is balanced by the acidic nature of chlorine oxidation reactions. So bleach is net neutral in terms of pH. There is small amount of excess lye in bleach (bleach is manufactured with a pH of ~12 to ensure that it remains stable) but the amount of excess lye is quite small. Calcium hardness, alkalinity and pH have more to do with scale than bleach.
    You can find lots of interesting information in this link (and print it out for your PB to read) - Certified Pool Operator (CPO) training -- What is not taught
    Matt
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    The dreaded clorox again! Just tell him you'll use Walmart brand instead then! Joyfulnoise covered all the bases of that conversation.
    .....and feel free to show PB that post!
    Nov 2015
    Humble
    101
    Thanks for the info,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I have learned to not say Clorox or bleach. Instead I say chlorine............yeah it is the same stuff but for some reason it is better received and causes less LOL
    Kim
    Aug 2014
    Northern IL
    4,615
    And if they ask you what type of chlorine, just say liquid chlorine.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    High pH combined with high CH cause scale. But not salt. It has nothing to do with scaling at all.
    Quote Originally Posted by blazeone View Post
    Divin Dave,
    Jan 2014
    Buckeye AZ
    807
    salt actually lowers your CSI scale a small degree. negligible until you keep a couple thousand ppm in the pool, but still, if anything it helps against scaling.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    As scaling potential reduction goes, you can get more of it by a pH reduction of 0.3-0.4 than you will from a typical level of Salt you'd have in a pool. It's very negligible indeed.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Ask the pool builder what happens to pools that run really high salt levels for their chlorine generator, and how is that salt okay but the salt from bleach isn't. His response is sure to be nonsensical and comical.
    The main reason pool stores and builders advise against Clorox is because you don't buy it from them. Funny thing is, every pool service truck I see -- and there are a lot in SoCal -- has the orange and yellow HASA crates in the bed. They might use pucks to maintain FC during the week when they aren't around, but when they visit, they use 12.5% bleach to boost the FC!
