Thread: Heat pump advice needed
    NJ
    291
    My 18 year old heat pump failed the end of last season and I need a new one? Looking for recommendations on brand. I have a 20 by 40 IG in New Jersey that I keep the solar cover on when not in use. Would like the water 80-84 degrees. Typically have pool up and running the end of April and close the first week in October. The current unit is 80,000 BTU/Hr but would like something larger if possible. I say if possible as the current breaker for the heat pump in 40amp and the Pentair continuously variable pump is on a 20amp breaker. The breaker in the house is 50amps and the wire is #6. Suggestions welcomed.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Heat pump advice needed
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    I meant to come back to this thread. I think you will be fine if you change the house breaker to 60a and put a 50a breaker for the heat pump and get a 140k btu heat pump. All of Pentair's heat pumps work on 50a breakers. http://www.pentairpool.com/products/...t-pump-405.htm
    NJ
    291
    Think I have it narrowed down between an AquaCal and a Gulfstream - any opinions on these?
    DFW, TX
    24,506
    No, not from me. Except I have heard of Aquacal and I haven't heard of Gulfstream. Quite a few people here have Aquacal heat pumps, hopefully they will chime in about how great they are.
