Results 1 to 13 of 13
Thread: first time pool owner: Question about heating and cooling a pool
    Feb 2016
    Austin, TX
    3
    Hello!
    My wife and I are building a house in Austin, TX that is going to have a 65', 25,400~ gallon lap pool. We want to be able to use the pool 356 days a year. We were originally looking at the "Aqua Comfort heat/chill pump" but from my research it doesn't seem like it would be able to heat the pool in the winter months to the desired 80 degrees. Their calculator seems to imply we would need 4(!!) units.
    So our next option is using both a
    "Aqua Comfort heat/chill pump" and a dedicated "Jandy JXi 399,000 BTU gas heater", although that's starting to get pretty expensive. Are there other options for heating/chilling a pool?
    Do the Glacier Pool Chillers work well? They seem much cheaper than the Aqua Comfort. Are there any other options?
    Here's all the info about the pool:
    • Salt water Chlorinator
    • Stucco Skimcoat on exposed exterior surfaces
    • PeppleTec interior surface
    • 6 Color LED Lights
    • Jandy JEP 2.0 Variable Speed ePump
    • Jandy DEV 60 DE Filter or CV 580 Cartridge Filter
    • 1-2 Surface Skimmers
    • Water Leveler
    • Never Lube Valves
    • Stainless Steel Ladder
    • In-Floor cleaning system
    • iAqualink - Smartphone Connected Controller
    Thanks!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Re: first time pool owner: Question about heating and cooling a pool
    What type of pool cover will you use? They are essential to maintaining heat.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2016
    Austin, TX
    3
    Quote Originally Posted by bmoreswim View Post
    currently we were not planning on having a cover at all. I wonder if a solar cover would allow us to just go with the electric heater/chiller and avoid having to add a gas line and buy 2 separate units? It doesn't get that cold here.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    A solar cover should work well.
    No need for any fancy ones either, 8 mil thick clear or blue will do.
    Dolphin E10 Cleaning Robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    Only 356 days a year huh? LOL! A solar cover will be required to hold in the heat overnight. I would do solar panels, if you have south or southwest facing roof available for the main heat source and supplement with a heat pump. The reason it is saying to use 4 units is because of the coldest month or two. Probably Jan/Feb. It takes a lot of heat in those months. The solar panels will also cool the pool by running them at night.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Quote Originally Posted by pooldv View Post
    ROTFL myself! I'm gonna crack you up with this one too...
    Maybe he's Jewish and is celebrating The Nine Days (365-356)...
    During the Nine Days, these additional activities are forbidden by Jewish law because they bring one to joy:[2]
    Home improvements, painting and new construction
    Planting trees, flowers or grass
    Laundering clothes, towels, tablecloths and bed linens
    Wearing new or freshly laundered clothing
    Making or buying new clothes, towels, tablecloths and bed linens
    Eating meat or poultry
    Drinking wine or grape juice
    Bathing for pleasure (i.e., one may not take a hot shower or bath, but may use cold water to remove dirt and sweat)
    Swimming for health or exercise
    Feb 2016
    Austin, TX
    3
    Welcome to TFP!
    haha oops. I was typing too fast
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Some acquaintances of ours built a lap pool in MD and wanted to swim during a long season. She planned to wear a partial wetsuit for the most borderline times. That could help you lower the temp during the winter.
    DFW, TX
    24,516
    LOL, did you add that last one for effect??? Seems suspicious!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    That's the great part, I didn't. Straight from Wiki.
    JoyfulNoise's Avatar
    May 2015
    13,264
    A pool that size will be very difficult to heat in the cold months. I doubt any single heat source will work well enough even with a bubble cover. The evaporative heat loss when the ambient air temp drops below the water temperature is the biggest factor. You typically can't heat an open pool of water more than a few degrees above or below ambient air temps. Your best bet would be an automatic hard cover.
    Super expensive - Yep.
    Only way to retain the heat and/or block the sun - Yep.
    Another option - build the lap pool inside an enclosed structure / pool house.
    Matt
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    WTF242, since you're building new, its a lap pool, and it sounds like you like to seriously swim, I am going to throw out a suggestion despite the expense because the payback in energy costs might make sense, especially if you're an early morning swimmer!
    Look into building in an automatic cover. That way you can press a button in the am, and dive in, without needing the pool heater on all night to maintain temp.
    I am in Michigan and heat my pool all season long, and well into the shoulder seasons where nights can be 40 degrees. I use a gas heater that does the job and uses between $200-300/ mo in extra gas -- it seems to cost less if its left to run all the time rather than big heat ups and cool downs. My pool footprint doesn't have enough room for a solar cover reel without cutting into a walkway and we don't want one anyway because like to just come out and dive in at odd times, including at night in the dark . But if there was one thing I wish this pool had, it would be a built-in automatic cover
    Remember that to maintain temp overnight for an early morning swim in open water (uncovered) means you have to be running the whole system overnight as even the beefiest heaters only get you a few degrees an hour. Many people seek to reduce pump run time to save on electricity. The latter and former don't go together
    I'm just mentioning these things since you're building and can design it to suit your druthers. This advice is more germane to folks who rise and swim early despite the weather If you think that might be you, give it some thought.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Feb 2015
    Austin, TX
    50
    I would seriously consider solar panels for water heating given our climate. Also, they can be used for cooling as well if you run the pump at night. I can't speak from my own experience with heaters since I have never used ours (too afraid of the gas bill), but since I have a similarly sized lap pool and I am also located in Austin, I am very interested to know what you finally decide on and what performance you get.
    IG plaster pools built in 1985 (?): 16k(?) gallons lap pool (62'x8') connected by a spillover to 17k(?) gallons squarish pool (22.5'x18'). DE filters Pentair NS-48(x2), polaris 280 (non-functioning). Inline chlorinator [removed!] -> Circupool Si60 SWCG [Newly self installed March 2016!]. Recently acquired dolphin nautilus+ [Summer 2015]. Still figuring out what else I have and how things work.
