Results 1 to 11 of 11
Thread: Shed over pool equipment?
    Mar 2013
    Yucaipa CA
    87
    My pool equipment is all out in the open and I want to put a wood shed over it. I am looking at a 8' x 12' Wood shed with a wood floor. I was thinking that I don't want to put it on skids. I would like to set the floor on the ground. I was thinking of digging out around the equipment pad about 3" deep to the size of the floor. Fill and level with pea gravel and put the floor directly on the gravel. I would use pressure treated 2x4's for the floor joists. I would also need to build the floor around the pool equipment leaving the floor open because all of the equipment is already mounted and working and I don't want to remove any of it. I would have drain pipes running out under the shed to divert unwanted water, back flush, etc. Also it think the gravel will aid in runoff in the shed if any water were to leak inside. This would bring the floor closest to the pad level without having to do major excavation. I think this would also keep the vermin from borrowing under the shed. I really don't want to concrete in a larger pad.
    Do you think this would work well?
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Shed over pool equipment?
    Judging from your location, I'd say it would be a good idea. What you propose would quite likely last a good long time.
    30,415
    That's doable.
    Another idea might be to sink 4x4's (probably six) into the ground and then put your joists and flooring up off the gravel (or dirt) by a few inches. That would make your new floor perhaps too high in relation to the equipment but give you a bit better platform.
    Best of all might be to dig out all around your existing pad and then bring your new floor (supported by 4x4's and joists) up level to the pad.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One thing to consider is whether you will get into need for a building permit.
    Mar 2013
    Yucaipa CA
    87
    Sheds in our city can be up to 120sq ft without needing a permit.
    skeeter
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    This was my solution:
    I kept it to 120 sq ft (which is allowed without a permit here as well) but I had to provide plans, engineering, a permit and have several inspections just like building a house. Had I known it was going to be treated as such, I would have made it much bigger and incorporated a bar and bathroom in it.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    ps0303's Avatar
    Jul 2011
    FL
    3,691
    Keep in mind your venting issues for the gas heater. You also need to have sufficient clean air coming in so the heater burns properly.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Quote Originally Posted by ps0303 View Post
    The vent is a 4" category III pipe to a wall termination. Clean air is provided through 10 sq ft of wall vents and an O'Hagin style tile roof vent.
    -Brian-
    POOL BUILD
    Jan 2014
    Buckeye AZ
    807
    We did exactly what op suggests: sloped roof wood frame over the equipment, though the 4th wall of the shed is our house. And to get around having a "permanent" structure requiring permits and HOA approval, it's just sitting on pressure treated 4x4s and not attached to the house at all. So free standing.
    We have sliding doors (like your closets in the house) for easy access in case repairs are needed.
    This gets the equipment out of our killer sun, but the air temp in the shed is pretty high; not enough air flow in there. So while the motor isn't getting 115 degree direct sun, it may be exposed to a higher ambient temperature. I need some more vents.
    I'll get some pics once we finish most of the trim.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Apr 2016
    Houston, TX
    208
    2016 pool build.... 18k gal. freeform style, built in round table, 18" jumping platform, travertine coping upgrade, travertine waterline, peagravel decking, saltwater pool (no spa), Quartzscape blue., 1.5hp Pentair pump, JANDY SWG, 48sqft Pentair DE filter, TFP-100 kit w/speedstir MYPoolBuild
    Houston, TX
    1,099
    Quote Originally Posted by BuckeyeChris View Post
    It's the UV from the sun that is most destructive, not just the heat by itself. The shed will prohibit the UV from degrading your plastics. adding vents at the top of the shed is best since heat rises. Also, determine which direction your prevailing winds are most dominant [esp during the heat of the summer] and make the vents fact that way. There are fans that are heat sensor activated for drawing out hot air, as in attic applications. good luck
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
