Thread: T104m201 fireman's switch
    May 2015
    Kailua, HI
    3
    Is there just 1 wire coming from the fireman's switch? My Raypak P-206A manual says to splice into the red jumper wire on the multi-pin plug that goes to 2 pins.
    Thanks
    22,542
    Re: T104m201 fireman's switch
    There should be two wires. It may be a loop of wire that you cut and connect to the fireman's terminals, but once connected correctly, there will be two wires.
    May 2015
    Kailua, HI
    3
    Thanks for the reply. I haven't received the new timer module, yet and can't find any pix of the connections. That makes sense as my Raypak heater has a loop between 2 pins, so I can connect 2 wires when I cut it. I think it is low voltage so I should be able to run 2 small guague wires for the fireman's switch.
    22,542
    It's just a input to the control circuit of the heater telling it that the pump isn't running so it ensures a shut down and it's not solely depending on low flow (actually pressure) to shut it down, so small wiring should be plenty.
    May 2015
    Kailua, HI
    3
    Mahalo!!
