Results 1 to 9 of 9
Thread: Is this an issue?
    Dec 2015
    Chino/CA
    203
    Is this an issue?
    On Saturday I replaced my spa light bulb, in the process of putting everything back together I broke the tab inside that the screw on top of the housing screws into. So the only thing really holding it in place is the the little metal bracket at the bottom. Is this going to be an issue? Can I replace it or fix it?
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Is this an issue?
    Pool tool, light wedge. Google it.
    Factory Warranty Station for:
    Dec 2015
    Chino/CA
    203
    Awesome!
    Thanks!
    Chris B.
    JoyfulNoise's Avatar
    May 2015
    13,176
    Quote Originally Posted by Pool Clown View Post
    That's pretty slick!! Gotta bookmark that one....
    Matt
    Dec 2015
    Chino/CA
    203
    I'm just curios, if I didn't want to use the wedge, what are my options? Could I possibly replace the entire ring inside?
    Chris B.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    There is a light ring that you can plaster in over the existing one. Best results occur when you re-plaster the whole pool. Then it looks as if there was no repair done.
    Dec 2015
    Chino/CA
    203
    Oh wow!
    Even though technically its on the inside for a lack of a better term?
    Chris B.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Actually it is over the existing light ring, technically outside the light niche.
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    The best solution I've ever used is an adapter made by Mac Manufacturing. They're a bit hard to find and kind of expensive at about $120 wholesale, but the result is rock solid. I've used them a few times with perfect results.
    Try their weird flash-based website but beware of the annoying music. There's a link to purchase the rings but it doesn't work.
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
