Thread: Inline water valve handle broke!!
    Baton Rouge, La.
    75
    In the 18 months of having the pool, the inline 3/4" valve handle to turn the water on/off to slide has broken twice. Can someone recommend a "well made" valve. I don't want a $2 one from Home Depot ( which looks like the one I have). Do pool companies have better valves or maybe a plumbing Company ??
    Thanks..Harry
    BTW..what about a brass valve? Any issue with the chlorine?
    Thanks
    Trilogy "Fiberglass" Pool,
    15x34 8900 gal.
    Pentair 1hp Super-Flo Pump
    Pentair CC100 Cartridge Filter, Pentair "Legend" Cleaner
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Inline water valve handle broke!!
    You're done SLAMing when:
