Thread: Pool Build Idea - Need Feedback
    Nov 2015
    Riverside, CA
    40
    This is not a build in the works, aside from my imagination. But I am wondering if anyone has ever seen someone split the spa and pool using glass..... but I am not talking about highly engineered thick glass to hold back the spa water.
    The idea is that the glass only needs to hold back a couple of inches of water in the spa when the pump or pumps are running. I am sure the glass still needs to be an inch or so thick... but it's not holding back 1000 gallons and trying to be water tight.
    In thinking about it, maybe the gap would need to be sealed in order to not require HUGE volumes of water to be pumped. But since water is on both sides, the glass isn't loaded like it would be if it were an aquarium.
    Here is a sketch I made.
    My Pool: Guessing; 7,500g total, has a spa. WhisperFlo WFE-28 single speed, MiniMax NT 400 heater, Pentair Cart. CCP320.
    BIL pool: 16,000 total water, (650g spa). 3hp InteliFlo VS, Hayward heater (unsure of BTU), Hayward DE6000. full drain/refill on Nov. 25th, running BBB.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool Build Idea - Need Feedback
    I suspect the material of choice would be acrylic or some other clear polymer like Polycarbonate.
    Jan 2015
    Tempe, AZ
    15
    The only material that should be used for a project of this sort would be Transparent Aluminum. ☺
    40,000 Gallons- "Lazy L"; IG-Fiberglass; Pentair Clean and Clear+ 520; Circupool VJ3 VS Pump (2.4 SFHP); Circupool SJ-45 SWG
