Results 1 to 9 of 9
Thread: Pool Deck Renovation
    We currently have the pebble concrete (exposed aggregate). What options are there to cover it? I really like the look of Kool Deck but think that is for new concrete only.
    What have you done, do you like it and what did it cost you?
    14,000 gallon IG plaster pool, Cartridge Filter
    Aug 2014
    Northern IL
    4,615
    Re: Pool Deck Renovation
    What do you mean by covering? Do you mean to leave the existing surface in place?
    Quote Originally Posted by MarianParoo View Post
    Ideally something that can be sprayed over the existing exposed aggregate. It's in good condition and I don't want to really tear it out.
    Aug 2014
    Houston tx
    2,524
    So if it's in good condition, why do you want to cover it? Do you not like it? Or do you want a different color?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Quote Originally Posted by Marlahoutex View Post
    I think the exposed aggregate is ugly and rough in the feet.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    I have NO idea if the kool deck can be done over old stuff like that BUT you could always call them and ask. If anything can it might be that.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    There are several concrete overlay options that can be colored and stamped or sculpted to look like almost any stone. Here are some,
    Stamped Concrete, Acid Stain, Polished Concrete Dallas/Fort Worth
    Decorative Concrete - Concrete Resurfacing - Concrete Repair, Dallas / Fort Worth
    Apr 2013
    Sacramento, CA
    2,769
    Look at the links above and do some more searching on your own for small concrete contractors. Many of these guys can do different things to your concrete. But you need to be talking to some contractors who can tell you what they can do and are experienced at. You don't want to hire a guy and as they are doing the work find out it is his first rodeo with that process.
    Quote Originally Posted by pooldv View Post
    Thanks for the links. This is what I am looking for
