Thread: SPA slowly draining/What we have tried
    Feb 2016
    Green Cove Springs
    2
    Ok, I have seen this problem all over the place and followed many solutions but not sure what our issue is. It may be the check valve but my thinking is that its not based on my testing.
    If you look at the pics below the first pic shows suction side. Left pipe to the 3 way valve is the spa drain. Second pic shows returns. Very top pipe above 3 way is the spa jets. Very bottom pipe is fountain in spa in which line has a check valve. We have a fountain pvc pipe in the spa just to be clear. I have checked both 3 way valves and they look in good order. A pool tech also checked them and agreed they looked good.
    We performed a test to try and rule out the check valve by turning the ball valve off for the fountain since it contains the check valve. The spa still drained down to the jets. It takes about 4-5 days for the spa to drain all the way to the jets. I dont want to just start changing check valves etc and then still have the issue.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: SPA slowly draining/What we have tried
    The spa is draining back into the pool?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2016
    Green Cove Springs
    2
    Quote Originally Posted by ps0303 View Post
    We believe so but it is so slow about an inch per day its really hard to tell. If we run the spa in spa mode for a few hours we see no water loss. So thats where we are dumb founded. Im at the point where Im tempted to just change out the check valve to see if thats it but if we close the ball valve and it still leaks that makes me think its not the check valve.
