Thread: Is this normal?
    Feb 2016
    Los Angeles, CA
    37
    Is this normal?
    So I've noticed a lot of debris floating around with the light on. During the day, the water looks clear.
    Is this a problem I need to tackle or is this normal?
    I just cleaned the filter this morning, after doing a drain and refill to deal with high CYA.
    22,000 gallon in ground pool with pebble finish. Pentair DE filter with Pentair VS pump. Built in the 70s but completely redone (including new pebble finish, equipment, and plumbing) in August 2015. K-2006.
    Aug 2014
    Northern IL
    4,615
    Re: Is this normal?
    Most of us have "floaties" that appear under lights. If your water tests are good, don't panic. Your DE filter can get them reduced. Harder for us with sand filters.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Is this normal?
    Yep, normal. There is always stuff blowing in the air and getting in the pool. It will all get filtered out eventually. It is worse at different times of the year for us. The fact that you can see that little bitty stuff is actually good. That means your water is very clear.
    Aug 2014
    Northern IL
    4,615
    Re: Is this normal?
    The most clear pool I ever saw under lights was ChemGeek's. Even he had some floaties. Not many, but still.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Is this normal?
    Do you use a skimmer sock? If not, try one...it sure helps grab some of the finer things.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
