Results 1 to 8 of 8
Thread: round bull nose tiles
    Feb 2016
    plant city florida
    12
    Has any one know of a source for 6" x 6" 1/4" round bull nose pool tiles? I have about 15 cracked tiles around my pool I want to replace but cannot find any source for replacement tiles. I have attached pictures of the type of tile I am looking for. I will need approximately 30 such tiles. 15 are cracked or broken but I would assume that I might damage the ones next to the ones I am replacing so I would need spares just in case.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: round bull nose tiles
    Would these be similar?
    Cepac Tile 6x6 Surface Bullnose Trim Tile | Glossy Aqua Blue | #623 SBN
    Google is your friend
    Feb 2016
    plant city florida
    12
    No they would not as the curve at the top is different. I can find some tiles similar to what you posted but none where the curve at the top is like the one I posted. Hence they will not match the contour of the ones currently in the pool. The curved top of the tiles mate directly to the cement deck around the pool. Using tiles like the ones you posted would leave a gap between the deck and the tile that the other tiles would not have. Here is an illustration of what I am talking about
    Attachment 45433
    Feb 2016
    plant city florida
    12
    Here are some photos of a side view as if the tile was installed.
    Attachment 45434
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I think they might call that radius bullnose. Sorry, can't find anything in that color, maybe visit your local pool or tile shop.
    http://www.diyadvice.com/diy/tiling/...rders-edgings/
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,407
    I wonder if you can find someone to make you a few tiles like that? You can even have the different color with an inlay on them so it will look like it was planned as a pretty accent.
    kim
    kim
    Solids | National Pool Tile Group look what I found!
    Feb 2016
    plant city florida
    12
    Thank you for those that responded. I was finally able to find similar tiles on Ebay. There are not an exact color match but with some creative placement I should be able to make them work, as the cracked tiles are where the pool transitions at an angle from the shallow end to the deep end. If others are looking for this type of tile here is the Ebay link. Aqua Blue Bull Nose Swimming Pool Tile 5 16 Thick | eBay
    Jul 2012
    Tallahassee, FL
    30,407
    I am so glad you found some!
    Kim
