Thread: Sealing concrete
    mikergibson's Avatar
    Jun 2007
    Mt. Vernon, Illinois
    Sealing concrete
    I have concrete cantilever coping which hangs over the edge 2" or so. My wan't sealed when the pool was put in and I haven't a clue about concrete whatsoever. Does it need to be sealed? Will it erode away in a few years from all the splashing water and waves when jumping in? If so can anyone recomend an easy sealer to put on? Also I have thought of applying one of those epoxy products? any opinions good or bad on doing so and are there any that you recommend? Thanks all of you for your help. I've only been on this site for 10 days or so but it has become my #1 morning read!
    My Pool:
    12K gal Fiberglass. Pentair DE Filter, Aqua Logic SWG, GoldLine Controls, Kreepy Krauley pool cleaner, MiniMax 250 Heater, Pentair FiberWorks Fiber optic lighting, Pentair 1 1/2HP Pump, a new shiny TF100 test kit, a clear pool and 3 happy kids
    Jun 2007
    Hollister, CA
    Are you talking about sealing the surface or the joint between the concrete and the pool? You DO need to seal the joint between the pool bond beam (wall) and the deck. I used Deck-O-Seal and it worked great. If you are talking about sealing the top of the concrete (where you walk), you don't need to do that. It won't erode away.
