Thread: Clorox ?
    Nov 2015
    Humble
    101
    Clorox ?
    Used Clorox for the first time and now pool water is soap like bubbles. Regal non scented.
    IG Gunite, 16' x 30', 3 1/2' - 5' deep, ~11K gal, Pebblesheen, Intelliflo VS pump, Clean and Clear 420 Filter, LED Color Lights, Taylor K2006 Test Kit.
    Build thread http://www.troublefreepool.com/threa...d-in-Humble-TX
    Aug 2014
    Shallotte, NC
    693
    Re: Clorox ?
    This can happen due to two possibilities:
    1) Scented bleach (OK, that's not it)
    2) Easy pouring or splashless bleach.
    It will go away by itself.
    Nov 2015
    Humble
    101
    Re: Clorox ?
    Used the splash less! Opp's. Hope it delutes out soon.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,593
    Re: Clorox ?
    Live and learn! My pool smelled real good one time---------you can guess why! LOL
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Clorox ?
    Although we recommend the plain, regular, unscented bleach w/o thickeners (the thickeners make it "splashless"), using the splashless on a "one-off" basis like this is not the end of the world. Last year I mistakenly picked up a bottle of the splashless Clorox that was mixed in with regular Clorox. Didn't realize it until I got home. Did not want it to go to waste, so I used it partly out of curiosity. The main side effect is the temporary bubbles that (in my case) disappeared after about 10 minutes or so. Aside from that temporary effect, it caused no other issues. However, I went back to using the plain bleach simply because it has one less additive that I don't need anyway. Now, I'm a bit more careful in shopping for bleach to make sure I get the plain version.
