Thread: OPinions Flexble PVC Piping
    Apr 2013
    Fayetteville, GA
    83
    I used some of this a few years ago with 0 problems. Seems to me to be great stuff. Recently I have been having some pool problems and a "professional" looked at my set up and was horrified by the flex pipe.... Seeking opinions.
    THX
    http://www.flexiblepvc.net/Flexible_PVC_Pipe_s/23.htm
    18 x 36' Liner ~26,000g, 1 Skimmer (Supply)- 2 & 1 1/2" pipe, 3 Returns (jets), HEAD- ?, FILTER- Hayward 12002, 230v, SWG- AUTOPILOT DIG-220, PUMP- Challenger 346204 w/ USA MOTOR (rebuilt) SF 1.25/,02, CLEANER- Polaris 280- AO Smith 3/4hp., FEATURE- Hayward 1.5 HP Super Pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: OPinions Flexble PVC Piping
    You will find that people up north where the ground moves a lot during freeze cycles like the stuff, but everyone else hates it, there are many threads on this topic you can find with the search function.
    Ike
    ps here is one Why not Flexpipe? Why 2 rigid?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I have used the 2" black flex a couple of times in koi ponds and it always held up great for many years. As Isaac says it is generally frowned upon here at TFP. The worst thing I have seen with the flex is that it can collapse on the suction side between skimmers and pump and it has to be dug up and replaced. But, I have only seen a few instances of catastrophic failures of flex PVC.
    Apr 2013
    Fayetteville, GA
    83
    I'm only using it on very short runs to my pump.
    THX
