Thread: Best brand and type of safety cover?
    Feb 2016
    New Hampton
    17
    Looking to purchase a safety cover for my free form in ground pool.
    Patio will be 8x12" pavers.
    What's the best safety cover brand and type out there?
    was thinking of a "super mesh" that blocks 95% of light from entering... do you guy's suggest something like this or is it better to go with a solid
    that has some drainage mesh in the middle etc.
    thoughts?
    thanks
    20x40 in ground free form kidney with bump outs, Omnilogic Automation, Turbo Cell 15, Hayward VSP, DE filter. Aquacal Super Quiet Heat Pump SQ175. 6 Pentair Magic Stream Laminar Jets powered by dedicated Hayward VSP pump with cartridge filter.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Best brand and type of safety cover?
    Where are you?
    Snow no snow?
    Trees nearby?
    Close the pool in winter .?
    You install or have a PB install?
    Feb 2016
    New Hampton
    17
    New York , yes usually fair amount of snow (except this year) Trees semi nearby but don't receive too many leaves from it, yes close pool for winter. I will install into paver patio. I'm very familiar with the current installation practices... however not as informed on which cover companies are really better then the other.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I personally like my "hybrid" cover...its solid, with a mesh square in the center. The reason I like it is that unlike a full solid, I don't have to drain it/us a cover pump once snow starts to melt, but at the same time the "solid" majority surface prevents any sunlight and much crud from getting in. I think mine was from Lantham as the PB used only lantham liners etc. at the time of the build, circa 2001 and prior to my ownership. The liner has now lasted 15 years, so I'm thinking Lantham is pretty solid in terms of quality This cover might be just as old, for that matter, as it was custom. If so, its had a good life span...two small holes I patched two seasons ago and obvious weathering but still highly functional.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
