Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Pollen (?) ring around the pool
    FloridaPoolGal's Avatar
    Jan 2016
    Altamonte Springs, FL
    98
    Hello,
    My readings and actions today:
    FC 5.5 chlorine added to hit 7.0. Level was 7.0 on Wednesday.
    PH 8.0 acid added to hit 7.4
    TA 110
    CYA ~60 as far I can tell
    Cleaned my Hayward C1200e filter. Pressure went from 18 lbs before cleaning to 8 lbs right after cleaning to 12 pounds after about 4 hours.
    Do you think the ring is pollen? I attached a picture of the ring around the pool which I wiped off today. I'm assuming it is pollen because we have it on our cars and it looks like it's on the pool screen roof. There's other small debris on the surface of the water which bugs hubby to no end. "Why doesn't that stuff get filtered out?" I'm pretty sure we have a 50% skimmer/50% main drain flow (is that what it should be?) but maybe the debris is too small and passes through the filter. Or we just get more the next day from the neighbor's trees!
    We have a cartridge filter and I know they don't filter particles as small as a DE filter would. 15 years ago we lived in a house where we built a vinyl liner pool with a DE filter, SWG, a pool screen and NO trees near. The water was crystal clear. I think hubby is expecting the same perfection but I don't think it's possible with the neighbor's trees dumping stuff onto the pool screen, especially when we have had lots of wind.
    Other than the ring and some very small debris on the surface, the water is beautiful (see attached photo)! Teaching hubby to use the test kit while I am out of town for a week.
    For those who read my intro post, no I haven't done my light yet. Did you read the post from the guy who recently did his light and about froze to death! Also, ignore the floating chlorine dispenser. It's empty and it there to entertain the cat. Also, I guess I have to take pictures with my phone turned sideways because I can't seem to find a way to rotate these.
    Approx. 20k gal, kidney-shaped, inground, concrete pool built in 1974. 33' long. 18', 14', & 15' across. 3' to 8' deep. Hayward cartridge filter (c1200e). 1 hp, single speed motor replaced 12/2015. In-line Pentair 320 Chlorine/Bromine feeder (do not use). Screened.
    Jun 2014
    15,103
    Re: Pollen (?) ring around the pool
    That would be my suspicion - pollen. Not much you can do there except try to encourage good surface movement to the skimmer. Do you use a skimmer sock? You know, like a nylon or paint straining net to catch small things that go right through the factor skimmer basket holes? I have a Hayward C1200 as well, and having that extra layer of filtering at the skimmer entrance does a fine job for my pool. The skimmer sock is a blessing for sure. Just make sure that you have good surface movement. It's that time of year where vegetation is waking-up, so we just have to watch it. Good to see you know what to do with your test results. Very nice.
    Dec 2012
    Manassas Park, VA
    207
    That looks like pollen to me as well. However if you wanted to confirm to make sure it is not something growing in the pool you could put a bucket of water next to the pool and after a day or two look at it. It should also have pollen it, I had to do this the first year with my pool as I wasn't sure if it was my fiber alternative of DE going back into the pool.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Aug 2014
    Northern IL
    4,615
    Remember to clean your filter when the gauge reads 10, (25% increase in your clean psi of 8).
    Skimmer socks are a great idea if you don't already use them.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Yup, that sure looks like pollen!
    Its spring time in Florida....here in Georgia we're not too far behind you. Yellow pollen will overtake everything for a month or so. My skimmer sock will be filled with the fluffy stuff and the sock will require close monitoring for a while, but it sure saves it from getting to the filter.
    Jan 2016
    98
    My pump pressure was back up to 11-12 lbs within 5-6 hours. The filter is a Hayward C1200e and is 6-7 months old. It got kind of gunked up during the phosphorous removal phiasco! If I stick my finger deep into the pleat, I can still feel some slime. I hosed it out really well until the water coming out the bottom looked clear.
    Is it time to purchase a new filter? Name brand? Other? I see other C1200 filters but not specifically the C1200e. What is the difference between the C1200, C1200e, C1200RE? Should I be looking to an old thread?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Brushing may help. I think it tends to stick to the sides, so it doesn't get filtered out like other particles. We have the same problem at our house in June. There is a yellow green cloud of dust on everything for a few days. I can even seeing flying through the air when the wind blows.
    Aug 2014
    Northern IL
    4,615
    Maybe this might help???? Re: How to clean a cartridge filter
    30,419
    Before you purchase a new filter, take a careful look at your chemistry. It sounds to me like you have algae growing in your water (even though you cannot see it).
    I would suggest you perform the OCLT found in Pool School and, if you do not pass, you should SLAM the pool.
    It also sounds like your cartridge is due for a thorough cleaning. There is an article in Pool School.
    Jun 2014
    15,103
    Hey FloridaPoolGal, when the time comes ...... I ordered my C1200 cartridge filter from Amazon. Just have your model number handy and it's an easy purchase at a much better price than locally at the pool store - close to 50% cheaper. Once you get a new filter, maybe consider deep cleaning the old one and saving it as a back-up just in case. HERE is the page Dave was talking about.
    Jan 2016
    98
    Quote Originally Posted by PAGirl View Post
    I think I'm happy to have it collect on the pool. It's not hard to wipe it off although it takes about 1/2 a roll of paper towels.
    Aug 2014
    Shallotte, NC
    693
    I'm pretty sure that is pollen. I know, with the warming temperatures, I've had to start using the skimmer sock that I haven't needed since the end of summer. pH is VERY important and should be checked daily, along with the chlorine. Knowing the CC level is as important as knowing the FC level. Complete test results would be helpful.
    Jan 2016
    98
    Quote Originally Posted by Texas Splash View Post
    I see cartridges available on Amazon but none of the size checking apps recognize my c1200e cartrdge. I'm assuming a c1200 is basically a c1200 but I'm very curious what the 'e' and the 'RE' mean after the c1200.
    Are you getting a Hayward filter or another brand for the great price? I think I paid about $85-$90 at my local Pool Shack for the Hayward c1200e.
    Jan 2016
    98
    Quote Originally Posted by ewkearns View Post
    FC 10.0 (starting another thread because I don't know what happened to get CL this high after adding chlorine yesterday morning! I tested late yesterday after adding CL and got this CL level reading. Thought I had made an error so told myself, "I'll just check it in the morning." Still 10.0 this morning, i.e. 20 drops to get the water clear during the test. Did the test twice.)
    CC 0
    pH 7.5 (added acid yesterday to get here)
    CH 375 This is slightly elevated from where we have been because we have had to add tap water 3 times over the last 2 months due to evaporation (we've had wind with low humidity).
    H2O 62 degrees
    Jun 2014
    15,103
    I see cartridges available on Amazon but none of the size checking apps recognize my c1200e cartridge. I'm assuming a c1200 is basically a c1200 but I'm very curious what the 'e' and the 'RE' mean after the c1200. Are you getting a Hayward filter or another brand for the great price? I think I paid about $85-$90 at my local Pool Shack for the Hayward c1200e.
    Here's what I ordered last summer:
    Pleatco PA120 Replacement Cartridge (about $54). I also ordered Hayward CX900F Filter Head O-ring (about $10) for my filter housing. Usually you can compare the measurements listed, and their website usually tells you if it's compatible with your filter housing (see the following)
    In comparison, the "ePoolshoP has those filters HERE, but for about $72. But you can compare the measurements once again. Oh, HERE is the Amazon link. Looks to be about $79 there. Humm. THIS is the one I ordered last summer for $55. The measurements between the two are very close. Amazon says this on the C-1200RE page:
    Cartridge For the Hayward C1200 Star Clear Filter CX1200RE
    . You might be able to use either filter. But at least you have a couple choices.... probably more with some more help from Google.
    Jan 2013
    9
    Yes, thats pollen. I have a pool service business here in So. FL and its that time of year again!
    Jun 2013
    South Florida
    118
    That same yellow ring showed up around my pool last week as well. I'm south of you in Palm Beach County. Just that time of year.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    Sep 2015
    SW Florida
    16
    I'm in SW Florida and the pollen is very heavy right now. Every thing around here is yellow.
    Does heavy pollen like like this burn up more chlorine?
    In ground shotcrete 9,500 gal.w/pebbletec, Pentair Intelliflo VS Pump, Pentair Intellichlor IC 40,
    Pentair cartridge filter, Built Right heat pump, TF-100
    Jan 2016
    98
    Quote Originally Posted by Coverdog View Post
    Doesn't seem to be. My FC level dropped 1 ppm in a week.
  20. Back To Top    #20
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Well...you really do not need my input at this point, cause by now I'm sure you know that is Pollen. I'm just a few hours north of you, and the pine pollen has been worse than normal this year. Ive learned now (the hard way) to follow the TFP method. It will prevent the problems associated with the pollen in your pool. Just my two cents
    47k, 40x20 IG plaster,SWG, 24 jets, 3HP Pentair Whisperflo 2 speed,Hayward Pro Series Sand Filter36" Tank S360T2 TF-100
