Thread: Pool spa dropping water level
    Feb 2016
    Florida
    1
    I replaced a check valve a year ago because a serviceman told me it was not working. They also took off the water jet covers and said that I had s leak at the skimmer. It was fixed. About 3 months later , the spa started to do the same thing. Could the check valve be the problem again? I paid over $250 to deal with it already. Is the set up proper , or should I reposition the check valve Is it in a proper position being at that height.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Pool spa dropping water level
    If the spa is draining down and the water level in the pool rises when the pump is off, back check valve.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Apr 2013
    Sacramento, CA
    2,769
    Paul meant bad check valve.
    Beyond that to answer any more could you post a picture of your pool and your equipment pad.
    Feb 2016
    Spring/TX
    57
    Is the check valve set up at your common return? If it is remove the check valve see if the gasket is broken. ( need to know what kinda check valve it is) If gasket is broken it's no good.
    Check the valve where the check valve door shuts to, see if there is build up or excess junk or glue that you would have to scrape off so the check valve can seal.
    Do you have actuators? if the actuators are open just even the slightest that will also cause your spa to drain.
    So the valves to spa return and spa suction has to be closed. If all of that is good then it could be your valve diverter. The diverter in your 3 way valve act like a door closing off one side
    causing the water to go to the open route.
    P.S If you have a chlorinator plumbed before your check valve and your check valve isn't chemical resistant then It's not going to last long. That chlorine chlorine will eat it up. Gwegan is right a picture would make it so much easier to help with
    your problem.
    40k Gallon Grecian true L Gunite Pool/Spa. Clean clear plus 520 cartridge. IntelliFlow VS-3050. Polaris booster pump w/ Polaris 360 cleaner. Silencer 1 1/2 hp Blower. Aqualink RS8 w/ Iaqualink 2.0 upgrade kit.
