Thread: Site Glass
    Feb 2016
    Murcia Spain
    5
    Site Glass
    As I was doing a backwash this morning and noticed there was no flow through the site glass. Pressure was as normal. It does look as though it was flowing on normal filter. As it is the winter here in Spain and the pool cover has been on for a couple of months now, I only do a backwash about once every two to three weeks instead of the normal once a week during the summer.
    I am English living in Spain since 2006. I think the sunken pool was put in around 2003. The pool I have is 12m x 4m tiled with a Roman end. about 2m at the deep end to about 1.3m at the shallow end. 3 inlet jets at the Roman end and 2 skimmers at the deep end. 72,000 litres with a 1HP pump
    30,432
    Re: Site Glass
    Are you sure it is not flowing? It simply may not be dirty. Are you seeing a significant pressure drop after you backwash?
    Feb 2016
    Murcia Spain
    5
    Re: Site Glass
    No drop in the pressure it seems same as it always is on backwash, about 12 to 15. Normally when starting a backwash the site glass shows a "swirl" of water and a bit of grit, then after a few seconds it runs clear. But now it looks clear all the time. Made me think the water is not flowing. Jets, skimmers everything seems OK Do you think there is a problem ?
    Jan 2012
    'burbs of Augusta, Georgia
    7,369
    Re: Site Glass
    I'm kind of curious as to why you are backwashing so often? In actuality, a *slightly* dirty sand filter works better than a pristine clean one.
    If your water is clean and clear you may just not be seeing the movement within the sight glass.
    Aug 2014
    Northern IL
    4,615
    Re: Site Glass
    A simple experiment would be to remove the site glass and turn on backwash for a second. Water would gush out if there was flow. I agree, it's probably just your clean filter from so many backwashes.
    30,432
    Re: Site Glass
    Perhaps better would be to go the exit point of your backwash and witness the flow as you are backwashing. If that sight glass has any age on it, there is a good chance it may be brittle and crack when you try to remove it. Lastly, you may start an air leak as soon as you start removal of that glass and your pump will un-prime if you allow the filter to drain.
