Page 1 of 13 123411 ... LastLast
Results 1 to 20 of 260
Thread: Georgia Pool Build.... FIRED PB need advice please!!!
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    I'm so excited to be starting an official thread with unofficial plans! Feel free to critique them.
    Jun 2014
    10,876
    Re: Owner Build in Georgia :)
    That's great! You must be very excited. Well, please take advantage of this forum and the experience here to list the proposed equipment from your builder quote(s). Perhaps with a little foresight, we can help you avoid future problems, save some money, or ensure your pool is maintained in an efficient manner. Nice to have you with us. Welcome (back) to TFP!
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,084
    That looks like it will be a fantastic pool! Is there a way to increase the resolution on the pictures? I get the general idea, but the words are too grainy to read. Glad you got some unofficial plans finally though!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Jan 2016
    TX
    157
    What an awesome pool! I'd try and incorporate the steps into the ledge to remove the amount of space they'll take up in the shallow in.
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    Thanks, guys!! I was wondering about the stairs too. I suppose with the tanning ledge people won't need stairs to sit on. Does anyone have a tan ledge around 12' x 8'? I'm hoping its big enough for 2 loungers and 3 bubblers. I'm also curious about the placement of the deep end bench...would it maybe be better at the end of the pool.
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    Mod Squad pooldv's Avatar
    DFW, TX
    18,266
    I would probably add a bench opposite of that one so there are two opposite of each other. Then kids can throw stuff at each other.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    19,813
    Find a chaise and measure it THEN measure around it and see how much room you would need to walk around and between them. That will tell you how big your ledge needs to be.
    Kim
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit, Become a TFP supporter!
    Jan 2015
    Austin, TX
    1,091
    I would do like was mentioned before and move your steps so they integrate with the tanning ledge. Then when they are moved I would move your light which is on the right side of the pool next to the tanning ledge on one side and have another one on the other side so they are both facing away from the house.
    The step on the far left side of the pool I would make another bench so it is symmetrical to the other side of the pool. (This is my engineering brain not wanting things asymmetrical.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    I personally think that steps shouldn't be a part of the tanning ledge. Before I built my pool, I was at a friend's and we were sitting on the tanning ledge and the kids would constantly be running in and out splashing all those that are around. Just a thought to keep in mind.
    Have you thought about having the slide go the opposite way and then you could eliminate the step out in the shallow end all together?
    My Build 20x40 Freeform Shotcrete (33k gal) pool. 3.6-8.6, Blue Granite Pebble Sheen, Tennessee Flagstone Coping, Sta-Rite System 3 Modular Media Cartridge Filter, Intelliflo 4x160 x SVRS, Rainbow Automatic Chlorinator, 1 LED light, Tanning Shelf, 15.6 Slide with 3 different height jumping rocks, Sta-Rite 333k btu propane heater, kool deck, TF100, Dolphin Oasis Z5
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    THANK YOU ALL!!! So many great ideas to think about. This forum is the best.
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    Quote Originally Posted by james63038 View Post
    That's a thought! By the way, I just looked at your pool build....our slide is going to be just like yours!! How do you like it?
    james63038's Avatar
    May 2014
    St. Louis, MO
    35
    I thought the same thing. We love our slide and the kids love it even more
    You'll really like it!
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    We're finalizing our plans tomorrow. I wanted the shallow end to be 3'9", but the designer suggests nothing deeper than 3'6". Is this the actual water depth or the depth including the waterline tile? My 7 year old is at least 4'5" already.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    1,827
    It's your pool! You and your family will be swimming in it (and paying for it!) not your designer
    I say, if you want 3'9", then do it. There are some folks on here who have 3'6" and wish they would have gone 4'.
    ​FINALLY FINISHED IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jannylee53's Avatar
    Mar 2015
    Manor, Texas
    657
    True! And it's the depth of the water. It's really shallow. I so wish we'd done 4.
    New pool build in Manor, Texas. 2015. 509 sq. feet; 31'6" x 19'10". Sunshelf & bubbler and waterfall sheer. Gunite inground pool. Pentair Intelliflo VS-3050 pump; Filter: Pentair Clean & Clear 420 Cartridge; Inline chlorination w/UV Sys;Lighting:Pentair IntelliBrite Color LED 120V;Cleaner: KK Racer w/booster.Bench/ledge;limestone Coping; Verona Tile 562 Decking
    Indigo blue's Avatar
    Apr 2015
    Boca Raton, FL
    216
    I thought about the same thing about the placement of the light as Ummm did. I'd really consider that and a bench opposite to the one on the deep end. I'll be watching you build
    Sent from my iPad using Tapatalk
    13k gallon 10x35 IG salt water pool 8x10 spa Hayward ecostar variable speed pump with remote. Diamond Brite cobalt. Diamond brite watercolors
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    805
    How have I missed this thread? Your pool is shaped like mine. I recommend step-outs on the benches on the side with the slide -- that way, the kids will not impact the sunshelf area at all. And, not sure of your depths, but this shape of pool is suitable to volleyball, with the "deep end" in the middle. Scratch that, with little kids, they need to JUMP, so a deep end is necessary. Maybe 4-8 makes more sense...
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and polaris cleaner (Jandy). TF-100 Test Kit w/ Speed Stir
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    Quote Originally Posted by Helen203 View Post
    Helen, we have a lot in common! I think we're also going with the same plaster color that you did too....AND my son was born in Annapolis!! How I miss eating at Cantler's. Your backyard is pretty amazing BTW
  20. Back To Top    #20
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    241
    This is our latest plans. I know it's a little weird putting the steps opposite to the house in the shallow end...but, it seems like the best use of space considering the slide location. We decided to go with 3'9" for the shallow end.
    We are also thinking about going from 18x36' to 18x40' to gain more shallow end. With the original 18x36' pool we only have a small 6' of shallow end based on the designer's slope location. We'd like to extend that to have a 10' long shallow end. The designer tells me that this won't cost much more since it's an owner build. She said had we gone with a pool builder it would be about $2k more for the additional pool length. Can anyone confirm that this change won't cause a big increase in construction price?
