Thread: Cartridge filter question
    I have a cartridge filter and the cartridge only seems to be be getting dirty on the bottom half of it, is this normal?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Cartridge filter question
    Could be debris settling to the bottom when the pump shuts off, or could be that the internal air bleed is clogged, or missing. When i used to take filters apart, i would see more dirt near the bottom.
    Factory Warranty Station for:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    sounds normal to me. Mine does the same.
    Divin Dave,
    Jun 2014
    15,103
    I have a single Hayward cartridge (C1200) and mine will seem to have more sediment near the bottom when I clean it off. Not sure which make/model filter you have, but as Pool Clown stated, gravity tends to pull some debris down.
    By the way ... welcome to TFP! And when you get a moment, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post. Oh, and don't forget to update your location. Welcome!
