Thread: Interesting story to share
    May 2013
    Needham, MA
    140
    Just spent some time this past week down in Bonita Springs FL. Family was swimming in the community pool for the condo owners surrounding it. Whoever is in charge of keeping it maintained should be let go, or spend some time on this site. First off, the water level was a good 3 inches low. Secondly, lots of debris in the water. Doesn't help that the skimmers weren't taking in anything as the water was so low. The absolute worst thing was checking of the levels. The gentleman literally just walked up the side of the pool, dropped in a few drops of reagent, saw that it turned color when it hit the water, then went on his way. I asked him what the reading was and he reply was, "where it needs to be". I asked how he could tell. He then acted as if I didn't exist and he walked away. It's no surprise that the pool surface already looks horrible even though it was just resurfaced last year.
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    Jun 2014
    15,217
    Re: Interesting story to share
    I wish we could say this is the first time we've heard that .... but .....
    May 2013
    Needham, MA
    140
    Just took my fathers testers that he uses for his hot tub down to the pool to check the levels. Used a Taylor basic OTO kit and the test strips he had. TC and PH measured the same on both tests. The TC on the Taylor turned almost orange, off the charts. Same with the strip.
    FC 4
    TC 10+
    PH 7.2
    TA 90
    CH 250
    CYA 40-60
    I was in the pool two days ago. Didn't have a strong chlorine smell then. However, yesterday bad storms all day and today is very windy. Lots of debris in the water. Can you have a CC of 6 or higher?? What would that do to you? Water is pretty clear.
