Thread: Help with draining lines
    Jul 2014
    Greenville, SC
    57
    We don't close our pool over the winter, but have a major leak right now and can't keep the water level up (liner needs to be replaced).
    Freezing temps are approaching, so I understand that we need to drain the lines. Can anyone here guide me through this process? I'm clueless, and the pool school article doesn't go into a lot of detail.
    2008, 22,700g, vinyl, IG, SWG, Taylor K-2006 FAS-DPD.
    (More info to come when I figure it all out).
    Aug 2014
    Shallotte, NC
    693
    Re: Help with draining lines
    Over the next 10 days, it looks like you have two days with a 30-31 degree low, with the remainder 33-47 degrees ..... highs as much as 70. Personally, I wouldn't be very worried.
    Jul 2014
    Greenville, SC
    57
    Oh, so one or two nights of freezing temps are fine? That's great!
    May 2013
    Long Island NY
    419
    Yea your fine. It takes a hard freeze with temps below 32 for days to freeze water in pipes and skimmers to the point expansion takes place. I bet your water is in the 50's now.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jul 2014
    Greenville, SC
    57
    That's great! Thanks.
    Jul 2015
    Tempe, Az
    123
    If they are exposed pipes (above ground I mean) and you are really worried, pick up some cheap moving blankets from harbor freight and wrap them up. You should be fine though.
    28K Gallon old-skool plaster hole in the back yard in desperate need of an acid wash and a fixed skimmer diverter (yes, it's still broken)
    Hayward SuperPumpVS pushing some giant hayward cartridge filter setup
    SharcVacXL and Zodiac G2 to keep things clean
