Results 1 to 11 of 11
Thread: Marine shrink wrap as pool cover
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    I was just looking at the boats being shrink wrapped for winter. Can I do that to my above ground pool for winter? I will use the blue food grade barrel instead of pillow. Or is the compression from shrinking too strong for pool?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Marine shrink wrap as pool cover
    Interesting thought but I have no idea how they get that stuff to work on something that large. Can it be applied for pool use? I imagine if you get it shrunk on there, the pool would take it.
    Anyone around here ever shrink wrap a boat?
    Essential Links:
    Casey's Avatar
    SW PA
    10,457
    Never shrink wrapped a pool or a boat!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    On boats they apply the film and then use a big, gas heat gun to heat shrink the film. So, there is some control over how much heat is applied and how much tension the film gets. It could be a whole new industry.
    Pysiek's Avatar
    Apr 2012
    419
    I just want to know if it's possible. I do not want to use the pillow because it might lost the air
    Mar 2014
    south central PA
    112
    On boats there is usually a high point that creates the tension and slope necessary to keep the weight of snow from being a problem, I think?
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I suspect that boat wrap stuff is not cheap
    Pysiek's Avatar
    Apr 2012
    419
    There is why I want to use the blue barrel. Also 32ft x 100ft marine shrink wrap is about $250 this you can cut to 3 pieces so it should last 3 seasons.
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by Pysiek View Post
    Sent from my HTC One M9 using Tapatalk
    I haven't used a pillow in several years and never had an issue. My pool freezes solid.
    Aug 2014
    Houston tx
    2,525
    Would you post a pic of a shrink wrapped boat? Sounds interesting to do it for a pool. How would you wrap it around the pool? Wouldn't the ends need to meet or would it stick to the deck? What kind of pool are you referring to - AG or IG?
    Sorry, I see you have an above ground pool so that makes more sense.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2014
    Oakbank, Canada
    389
    Shrink Wrapping a boat - YouTube a boat being shrink wrapped
    Shrink Wrap an RV for Storage - YouTube, a RV being shrink wrapped.
    I have no idea where to get the shrink wrap, call your local boating store, Google is your best friend as well.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
