Results 1 to 9 of 9
Thread: Soda Ash and TA Increases for upward pH changes
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Also, don't use soda ash to raise pH. It will also raise TA a lot and you don't want that.
    You sure about that?...I only use soda ash and it has very little affect on my TA...with 2 entirely different pools I've managed.
    Dolphin E10 Cleaning Robot.
    JoyfulNoise's Avatar
    May 2015
    13,259
    Re: Need help with chemicals
    Quote Originally Posted by borjis View Post
    Soda ash (sodium carbonate or washing soda) raises pH and TA. Baking soda (sodium bicarbonate) raises TA without any measurable effect on pH. Borax raises pH but not TA. Aeration raises pH.
    Matt
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I'm not trying to start an argument or derail the topic but my testing and adding of chemicals contradicts that statement.
    I raised my TA from 50 to 70 with baking soda last saturday and my ph went up .3
    and when raising ph with arm & hammer wash soda from 7.2 to 7.8 my TA stayed at 70
    perhapsit was such a small change it doesn't apply in my case.
    May 2015
    13,259
    Let's not get into it here as this is not your thread. I would suggest you start a new thread in the Chemistry 201 subforum with you exact water parameters before you added anything, what you targeted for new values and what you added (amounts and sequence of adding them).
    In large quantities, baking soda can raise pH a little but not much. It does this by consuming a proton and forming dissolved CO2 which then off-gases. That is a very slow process. Most of the sodium bicarbonate remains as bicarbonate anion at pool water pH and will not change the pH.
    Sodium carbonate, by contrast, adds carbonate anions which, at pool pH, will be quickly driven towards the formation of bicarbonate by the equilibrium chemistry (carbonate is not thermodynamically stable at pool pH). In order to do that, it consumes a proton (H+). So sodium carbonate both raises the pH AND creates bicarbonate (TA).
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Soda Ash and TA Increases for upward pH changes
    Hey Guys,
    I moved these posts here to clean up the other thread. No problems with the discussion, but it was too much to leave in place. Although not so Deep, I put it here as 201 will likely be merged here in the DE at some point.
    Thanks Fellas!
    Essential Links:
    30,432
    The quotes below are taken from the description of Soda Ash from Leslie's Pools
    Our Soda Ash quickly raises both pH and Total Alkalinity levels to more acceptable ranges with ease.
    If your pH or Total Alkalinity levels are off in your pool’s water chemistry, our Soda Ash is a quick, safe, and effective way to correct both.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    All I have to do is add well water.
    Essential Links:
    DFW, TX
    24,514
    lol! Our city water has plenty of TA too!
