Results 1 to 7 of 7
Thread: Clamp Band; Pentair 4000 series
    Feb 2016
    Newbury Park, CA
    2
    I am new to TFP and to pools. Moved from Chicago to a home with a pool with and older system.
    The clamp/band knob and T-bolt is stripped. Is there a way to replace both (replacing
    parts and welding)? The price for a new clamp band is very high. Any ideas that any members have used?
    Thanks
    Jun 2014
    15,171
    Re: Clamp Band; Pentair 4000 series
    Feb 2016
    Newbury Park, CA
    2
    Quote Originally Posted by Texas Splash View Post
    You're right on ! I've seen these but was looking to replace only the T-bolt and Knob (both stripped), then, have
    someone weld (Mig or Tig) the T-bolt bracket back together. The T-bolt and knob would cost about $40.00, and welding would cost another $20. (maybe ).
    Didn't know if anyone out there had tried to repair one of the clamp bands.
    I'm just trying to save save save !!!!!
    Thanks for the reply,
    Bruce
    Jan 2016
    San Bernardino, California
    9
    Bfine,
    I'm in the same situation with an old Hayward DE Filter. I'm hoping this will be my fix.
    5/16-18 bolt and a sort of nut found in the hardware cabinets at HD. The bolt is 4" long but not 100% sure if it is long enough. I didn't measure the one on the clamp prior to purchasing. Obviously, I'm going to cut off the hex head on this setup and use a washer and nut to button it all up.
    Plus Red Loc-tite at the nut for good measures.
    ~40k gallons 40'x20' - 10'deep end 3' shallow end
    Hayward D.E. Filter (DE4820)
    Pentair Master-Temp 400K
    Filter Pump Hayward Supper II Pump SP3020
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by aespinoza101 View Post
    Bfine,
    Exactly. That round thing is called a barrel nut. You can also buy a piece of All-thread instead of a bolt and cut it to length.
    Dec 2014
    Riverside California
    482
    Bfine,
    If you use red loctite 271 you will have trouble ever getting the nut off again. The red stuff is permanent and would require a torch to get the nut off. Go with blue loctite 242 and you will be able to get the nut off with a wrench.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jan 2016
    9
    Your correct about the red loc-time being permanent. What I meant was loc-tite on the barrel nut to lock in the stud on that end.
