Thread: Doughboy Sidewalls bent at bottom rail and short to top
    Jun 2014
    new york
    26
    Actually I have similar problem. I try to fix filled pool. Hired guy with bobcat who damaged little steel walls. I will straighten those walls but not to original exact dimmension.
    What do you think? If walls will be bent little 1/8-1/4". After that will come foam. Will liner cover small dents? I plan also get some angle bars and weld extra frame to support everything btw.. I know best way would be install NEW walls but mine aren't rusted. Hope I could keep them
    Mod note: This post was split from this thread:
    Doughboy Sidewalls bent at bottom rail and short to top rail
    Kim
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    Re: Doughboy Sidewalls bent at bottom rail and short to top
    Are you still trying to repair while it is completely filled? I would also suggest spraying some sort of paint/anti-corrosive epoxy where the dents are even if there are no breaks or rust spots. If there are weak spots, rust is probably around the corner.
    If what I'm picturing in my head is what your planning, I think the added support to the frames and walls could work, but honestly if you could provide pictures you would probably get some GREAT responses from others who have tried similar repairs in the past.
    Good luck with your project, I hope you get it all sorted out!
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    Casey's Avatar
    SW PA
    10,444
    Pictures are worth a 1,000 words and are extremely helpful.
