Thread: Acid washing Liquidator lines
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    I'm sure some people have already acid-washed the WS off their LQ lines.
    How do you pour the acid water into the narrow orifice of the tubing?
    Do you use a syringe or a funnel, and if yes, where do you get them?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Re: Acid washing Liquidator lines
    Soaking the tubes in a large plastic or glass bowl of acid is probably the simplest approach. Lower the tube in from one end, so it fills up completely, and then remove the end that went in first and pull it out slowly so all the acid drains out through the other end.
