Thread: Gunite Question
    Oct 2014
    Tulsa, OK
    31
    Gunite Question
    My pool builder is planning on doing gunite tomorrow but we had a ton of rain today...
    Does this pose any problems? Ok to do gunite on wet soil?
    Thanks!
    Adam
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,751
    Re: Gunite Question
    Ideally the soil should not be wet as that will increase the water/cement ratio and decrease the cured strength of the gunite. In some instances this is unavoidable but should be prevented.
    How much water is in the hole?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Oct 2015
    Pentas/TX
    28
    Re: Gunite Question
    I hope he doesnt shoot over puddles!?!?! "wetting" the soil before pouring is normal in hot climates' it helps to delay the concrete from curing so fast depending on the mix design. This being said, my experience is in typical concrete mix not shotcrete or gunnite, but i would put my money on any concrete mix being affected in its w/c ratio when u pour it over any considerable body of water. If your soil is mud when being poured , i would hold back if it were me, but if its just wet being it was a normal rainy day then i wouldnt worry. Just my opinion.
    40x20 Rectangular (3'to6' depth),Cantilevered Deck, Whisperflo 2HP FullRated, DE 60 SQft Filter, 2 Intellibrite 12V 5G Color Lights, Intellibrite Controller
    Oct 2014
    Tulsa, OK
    31
    Re: Gunite Question
    There is a large puddle that they are going to pump out tomorrow morning and plan on shooting shotcrete tomorrow afternoon.
