Results 1 to 7 of 7
Thread: water level reached top of liner
    iam4iam's Avatar
    May 2012
    Johnson City, TN
    228
    I don't cover my pool in the winter, nor do I drain it. This winter, for the first time, the water level has reached the top of the liner. I am assuming that because the level is right at the top of the liner, that it has already overflowed behind the pool wall some. Is this a serious enough problem that I should drain or can I just let nature run its course? (My only means is to siphen since I have the skimmer closed off and empty for the winter and I don't own a portable pump.)
    ~18,000 gal (16x32) vinyl
    Hayward sand filter
    Circupool RJ45 SWG
    Hayward Max-Flo XL SP2305X7 pump (0.75 HP)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: water level reached top of liner
    No big deal. Water is in the ground anyway. Starting a siphon is the easy way to lower the water. Anchor the pool endo the hose where you want the water line and it will stop when it gets there.
    iam4iam's Avatar
    May 2012
    Johnson City, TN
    228
    Thanks. That is kind of what I figured, but I wanted to be sure.
    Hayward sand filter
    Circupool RJ45 SWG
    Aug 2014
    Northern IL
    4,615
    As a pool owner with ground water issues, I would recommend only draining just a tad. You want to keep the inside pool pressure pushing against the outer groundwater until the groundwater recedes. If you drain too much, the out-of-pool groundwater pressure may make things worse.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    JohnT could you explain that siphon technique?
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Jun 2014
    15,249
    dw, I'm not sure JohnT is on-line at the moment, so I'll try to interpret and he can correct me if I'm wrong. But once the siphoning is started by filling the hose and dropping the outside end to begin draining outside the pool, the end of the hose remaining IN the pool is anchored - anchored somewhere inside the pool at a desired level to where once the water drops to that hose-end opening, it will automatically catch air and stop draining/siphoning. That way you don't siphon more water than what is needed. I hope that's about right.
    Disclaimer - If I'm wrong, it was not me that typed this but actually one of my teenage boys playing a prank and impersonating me.
    SW Indiana
    9,199
    Quote Originally Posted by Texas Splash View Post
    Exactly.
