Results 1 to 12 of 12
Thread: Salt to soften water in NON-SWG pool?
    Jul 2015
    Tempe, Az
    123
    I switched the lagoon over to liquid chlorine after the flush & refill - but, Can I throw some plain old water softener salt in to help soften the water a bit?
    I found something online saying it was OK to just toss some in, but I don't know what level I would be aiming for, since I'm still using Chlorine to control the algae?
    28K Gallon old-skool plaster hole in the back yard in desperate need of an acid wash and a fixed skimmer diverter (yes, it's still broken)
    Hayward SuperPumpVS pushing some giant hayward cartridge filter setup
    SharcVacXL and Zodiac G2 to keep things clean
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Salt to soften water in NON-SWG pool?
    Yes, you can. I would start with around 1,000ppm (use Pool Math to figure how much to add) and see how that feels. You can always add more. Most SWCG require salt in the area of 3,000 ppmas a reference.
    Here is an old post ont he subject
    The best thing to use to raise the salt level is water softener salt. Look for salt that is 99.4% pure or better and doesn't have any rust inhibitor or other additives. The best choices include Diamond Crystal Solar Salt Extra Coarse Crystals in blue bags, Morton White Crystal Water Softener Salt in blue bags, or Diamond Crystal Sun Gems Crystals Water Softener Salt in yellow bags.
    Water softener salt pellets will also work, even though they dissolve more slowly they are still fine. Pool salt is also fine to use, but tends to be much more expensive. Potassium chloride will also work, but you need 17% more of it and it is more expensive. Avoid table salt, rock salt, and deicing salt.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,213
    Just note that, when you add salt, the color of the water will change ever-so-slightly. It'll take on a very slightly green-blue shade. It's very subtle, but if you have a good camera and can get the lighting and position right, you can definitely see it.
    Matt
    Jul 2015
    Tempe, Az
    123
    Thanks Folks! I'm going to give it a whirl and see if the water feels any better. At least it's an inexpensive experiment. (But I need to find salt test strips....)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    TFTestkits.net has some. But, you don't really need them the ppm isn't going to be important. Add 1000ppm according to Poolmath and see if you can tell. If not, then add another 1000 ppm. My pool has about 3400ppm. +/-500 ppm.
    Jul 2015
    Tempe, Az
    123
    Thanks again.
    Eeek...it wants me to add 400 lbs of salt to get to 2000ppm. (based on 2 year old water quality report sodium levels...) althought that's only $20 LOL
    I did go ahead and dump in 2x40# bags. For those that are wondering, I bought the Mortons non-additive water softener pellets, I think they where $4.50 a bag. Took about an hour for the pellets to completely dissolve. Roughly I should be around 500ppm according to the calc.
    I'm going to let the water mix a bit overnight, but first impressions is I can "taste" the salt, but that's at the surface. I'll see if I can source some salinity test strips locally tomorrow.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Some people can taste it at 1000, but not many. Lots of people say they love the feel of salted water, so let us know hat you think.
    Essential Links:
    Aug 2014
    Northern IL
    4,615
    Many people report that borates improve water "texture". Here is a link about it: So you want to add borates to your pool--Why and How
    DFW, TX
    24,497
    I like the salt and borates in my pool, definitely feels great. I also do epsom salts in the hot tub and I put some dead sea salts in both of them a while back. I can taste the salt in my pool for sure. Nothing like ocean water but it is there in the background.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Over to DVs pool if you need some mineral enrichment.
    Essential Links:
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Is this true of SWG pools as well? Does the SWG effect the water color and give it a greener hue?
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Oct 2014
    San Antonio, TX
    449
    No green hue in my pool. I have white plaster. BTW, my son is staring at a frog...ImageUploadedByTapatalk1456410021.754496.jpg
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
