Thread: Spray painting the Liquidator tank
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    A few approaches were suggested here last here about how to render the tank wall more opaque in order to minimize chlorine degradation by light.
    Some reported using spray paint. I wonder which paint brand and color sticks and has a good opacity.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Re: Spray painting the Liquidator tank
    Krylon Fusion is a great paint for that situation. The color shouldn't matter very much.
    Mar 2007
    San Rafael, CA USA
    Any color of the paint will be opaque so will block the UV, but white will reflect the best so will keep the tank the coolest.
    I used an Epoxy Appliance white. It holds up really well, just takes a long time to dry. I left a masked off strip down the side so I could see the level.
    ~25k G 20x40 Free form plaster
    Pentair FNS Plus 48 sq/ft DE
    Pentair Challenger 1 HP High Flow E.E.
    Zodiac G4
    8 gal Liquidator 3/8 line conversion
    Sundance Palermo Spa w/ozone and gazebo
    LQ 3/8 Line Conversion
