Results 1 to 8 of 8
Thread: pH bounce...new startup
    Jan 2015
    marco island, fl
    10
    Just plastered with mini pebble. Filled 2 days ago and just added some acid. pH shows at least 8. CH is 90. ALK is 110. When performing the acid demand test, one drop will send the test sample down below 7. I've never seen this before in a stable pool. I'm running the filter and brushing twice daily. Pool contractor added some chlorine...I believe it's at about 3. I've never re-done a pool before so I don't know if I should be chasing pH or let it go for a few days at a time.
    Jun 2014
    15,008
    Re: pH bounce...new startup
    pH should always be watched, so it's good you are keeping a close eye on it. Here's a good reference for new plaster: Pool School - Start-up New Plaster. But we always emphasize to follow what your builder/contractor recommends so that you don't void any work on their end. Once they give you the green light to manage on your own, it's TFP all the way.
    Jan 2015
    marco island, fl
    10
    Yeah, I've read that reference. None of it matches what my builder did exactly. I'm kinda wingin' this on my own. And I'm not getting any dust at all....strange I thought.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    fishing our way is science based and daily living tested BUT your PB holds the warranty card so keep that in mind.
    Kim
    Jun 2014
    15,008
    Much of the advice (chemically) provided by builders leaves us scratching our heads. You would think they should know some of this - even the basics, but it's clear many don't. Nonetheless, make sure you follow their warranty recommendations. If you feel strongly about something (i.e. high pH or low FC) and wish to discuss it with them, by all means do that. Don't throw TFP in their face because many of them get defensive right away, but be armed with the knowledge you've learned here to ask the right questions so you can make the best decision for your pool.
    Jan 2015
    marco island, fl
    10
    Seems there might be a reagent issue. Maybe age. I tested again and the sample didn't swing as wildly. I'll report back when (if) I nail this down.
    Jan 2015
    marco island, fl
    10
    Figured it out, I think. TA had drifted lower than I thought. Once back up the acid demand test functioned normally.
    Jun 2014
    15,008
    Copy that. If numbers start to get weird on you later, let us know and we'll re-address. Have a nice day.
