Thread: Missing part for my pool filter (Swimquip DES 60)
    Feb 2016
    Plano/Texas
    3
    I have a Swimquip DES 60 filter and I need a couple union adapters, but it seems that particular part is now obsolete? Any suggestions on where I might could find this part? The mfg code for the part is U111-208P. Attached is a pic with my filter details. My filter is currently connected to my push/pull valve using a flexible rubber coupling with clamps, but looking for a more permanent solution that can stand a little higher pressure when running my hot tub.
    Thanks!
    Jun 2014
    15,212
    Re: Missing part for my pool filter (Swimquip DES 60)
    INYOpools.com has THESE in stock right now. $13.99 each. Should be the right one huh? Swimquip DES Series DES25-01, DES36-01, DES51-01 or DES60-01 Replacement Part Schematic
    Feb 2016
    Plano/Texas
    3
    Thanks for the reply! I'm not exactly sure if that one is specific for the DES36-01 model or not? the schematic you link above shows a difference mfg code.
    Jun 2014
    15,212
    I called INYOPools and he seemed to think it was a match when I mentioned your DE filter. But you can call them to confirm. Good luck!
    Feb 2016
    Plano/Texas
    3
    Cool, thanks for your help!
