Results 1 to 13 of 13
Thread: Circupool V3 VS Pump. Just installed
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Nice pump .. need info on run times ??
    Any ideas , I have.
    4:00pm-7:00pm. At 100% for krepley krawley
    7:00pm-1:00am At 55% to filter
    Am i even close ??
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Circupool V3 VS Pump. Just installed
    Seems like excessively long run times. Is that needed for the SWG or another reason.
    Mark
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yea i have a swg and in floor caretaker 99's
    Just trying to figure it out , my water is still 54 deg, soo i really don't have much clorine usage at this time .
    Pool is approx 30k gal.
    Sean Hannon
    30,403
    Is the pump running in the second picture? Looks like you have air in the basket. Sorry to be a busybody but you don't want that.
    Jul 2015
    Central Valley CA
    1,107
    55% for filter/circulation seems a bit high for VS pump I run mine at 1100 RPM (so more like 31%) 3 times a day for a total of 4 hours. Will probably be more like 6 hours during swim season The reason I don't do a single run time is doing it a few times skims the surface clear and we are getting a bit of pollen right now, may or may not result in a cleaner pool but it visually looks better and therefore makes my wife happy.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Multiple run/skim per day does keep a pool cleaner because the stuff is in the basket/filter and not sinking to the bottom. And happy SO is a bonus!
    1100rpm is the magic number for my pump too for filtering, skimming and making chlorine.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yes the pump is running, it looks like air i agree but it isnt , and no air going in the pool through returns.
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yea after looking at it again is does have a problem ...
    Strange though no air going into pool but if i crack the valve on top of filter i do get some air .
    Arguuu i hate suction leaks !!!!!
    Sean Hannon
    Dec 2014
    Riverside California
    482
    If I run my VS pump at 1500 RPM I get what looks like air in the basket. If I run at 3000 RPM there is no air in the basket. I think the lower flow just can not pull the water to the top of the basket, and it looks like air.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I was having trouble getting any good flow rate at lower rpm's ( the whole reason i bought the vs pump )
    Turned out after i cleaned the D.E. Filter it's working good now.
    Iam able to generate clorine ( circupool RJ 60 ) at 55%flow , keeping the cell full of water.
    And for running the krepey krawley i need 90-100 % flow rate.
    So i started running a 3 hour 100% flow followed by 6 hours at 55%flow.
    Stiil gonna need some tweeking, maybe to much run time now ??
    I have a big Raypack Heater what is the best flow rate to use when heating ?
    The heater heats even at 40-50% flow rate.But what is the best speed to heat quickley??
    I only use the heater for the SPA, except i do heat the pool at spring break for a week.
    Thanks for any info...
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yea thats what i have too , i cheched for suction leaks with the hose , no leaks.
    I called the factory teck support and he said at low flow rates the water level in the basket will go down a little bit.
    Sean Hannon
    DFW, TX
    24,450
    My pump gets air in the basket at 1100 rpm and not at 1950 rpm. It always has
    (4 years) and has never been a problem. Cleaners need a lot of water flow to operate properly. You only need to run the cleaner long enough to keep the bottom clean. I would start at an hour and if it stays clean good, if not increase it 30 min. Then run at the lower speed a couple of hours and if that generates enough chlorine and your pool is clean then you are good to go. Increase run time if you need more clean time or more chlorine.
    I'm not sure about best flow rate for a heater. My heat pump, not installed yet, says to set the flow where you get a 4-5 degree temp increase.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Ok the results are in and we are saving $40.00 per month on electric bill with this pump.
    Sean Hannon
