Results 1 to 8 of 8
Thread: Diving Boards
    Dec 2015
    Orange County, CA
    9
    Diving Boards
    I'm building a new pool and plan on installing a diving board. The 2 options I am looking at are the SR Smith Salt Pool Jump System - which uses a kind of leaf spring type system, and the Flight Deck II - which derives its springy-ness from the board itself flexing. Does anyone have experience with either one of these that wouldn't mind weighing in? Also, my pool dimensions will tolerate either a 6' or 8' board - any preferences? I am looking for the greatest "fun factor" rather than aesthetics. Thanks!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Diving Boards
    Have you checked with your home insurance first, many of them will not cover pools with diving boards. And for a second question is your pool big enough / deep / long enough to safely install a diving board, mine is a 20x40 traditional hopper end, and I feel it is about the minimal size to consider having a diving board.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Diving Boards
    Welcome to TFP!
    Once you solve the insurance, and safety matters a board is fantastic fun if that's what you want. If you want spring and bounce, you need a board with springs. Those without are very stiff and lack that extra bounce you are likely looking for. We went with a spring model and couldn't be happier.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,451
    Re: Diving Boards
    Try Travelers Ins if you have trouble, they seem pretty open to pools. My rates didn't change and they didn't even ask about a diving board. Unlike my brother in FL who had to remove the diving board and the brackets to mount it had to be cut flush with the deck.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Diving Boards
    Few residential pools built today meet the minimum requirements for a diving board under the ANSI standards. http://srsmith.com/media/47241/06-052ansi-standard.pdf
    I have a rock
    Feb 2011
    Petaluma, Ca
    665
    Re: Diving Boards
    I got the SR smith cantilever jump stand with the 8' board, has a lot of spring. My son can do a 1 1/2 easily and is close to doing a double, I'm lucky to get around once. When I told my insurance co about the pool and board, they weren't worried as long as the pool met the requirements as far as depth and bottom contour.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Diving Boards
    The thread seemed to be taking a left turn from discussion of the type of diving board, to insurance companies. I have moved the insurance comments here: Insurance Diving Boards
    Support the site
    Feb 2011
    Petaluma, Ca
    665
    Re: Diving Boards
    I did need to re powder coat the cantilever stand after only 2 years, starting to rust, so that may be a good reason to get a different type of base.
