Results 1 to 7 of 7
Thread: hydrogen peroxide vs monopersulfate as an oxidizer
    Feb 2016
    Providence, RI
    5
    what is the difference between 'hydrogen peroxide' and 'monopersulfate' when using them as oxidizers? Is one better or more recommended than the other?
    thanks.
    20,000 gallon indoor saltwater pool.
    36' x 18' with vinyl liner. 3 1/2 shallow end, 4 1/2 deep end.
    Aqua Rite Electronic Chlorine Generator/ Hayward Turbo Cell-15 Salt Cell.
    89 degree water temp/90 degree air temp.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: hydrogen peroxide vs monopersulfate as an oxidizer
    It depends on what you are doing overall, but H2O2 will react and consume Chlorine, and MPS will not, however MPS will falsely show as CC on the DPD and FAS-DPD Chlorine test unless you use a special add on test interference remover. But before we get into that too far, let me ask how are you maintaining your pool, and why do you think you need a supplemental oxidizer? I too have an indoor pool, and rarely need supplemental oxidation, to the point that while I bought an Ozone generator for the pool a few years ago I have never bothered hooking it up, as I find that by following TFP methods I only run into a need for supplemental oxidation once or twice per year after large swim parties, and then I just use MPS.
    Ike
    p.s. I do note you keep your water about 5-6 degrees warmer than I keep mine
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Both are oxidizers. Hydrogen peroxide is typically only used in conjuction with a biguanide sanitation system. Alone, hydrogen peroxide breaks down pretty quickly in pool water.
    Monopersulfate is a very good oxidizer as well and can be used in conjuction with a chlorine or bromine system to oxidize bather waste, break down combined chlorines or reactivate bromide to bromine.
    Hydrogen peroxide cannot be a sanitizer on its own. Simply an oxidizer that is actually best used when FC levels are too high and immediate FC reduction is necessary.
    MPS is useful, but in many cases, simply using chlorine (liquid bleach) is cheaper and just as effective, assuming CYA levels are not far too high.
    Isolated Spa - 345 Gallons
    Feb 2016
    Providence, RI
    5
    thanks guys, good info. My main concern, as you noted, was that I had read MPS will falsely show as CC on the DPD and FAS-DPD Chlorine test. Does Hydrogen Peroxide give the same type of false reading?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Not to my knowledge, but since it consumes massive amounts of Chlorine you would be fighting yourself since you have an SWG.
    JoyfulNoise's Avatar
    May 2015
    13,236
    Quote Originally Posted by RockyStandish View Post
    Taylor sells a total oxidizer test kit that lets you measure the MPS levels and corrects for the interferences on the DPD-FAS test. The K-1520 works with the DPD-only test kits (K-1004 & K-1005) to remove the MPS interference and costs about $25. The K-1518 is a DPD-FAS chlorine test that includes the reagents necessary to test for the MPS level as well. That kit costs ~ $82.
    H2O2 in a chlorinated pool will not last long enough to interfere with the chlorine test unless you add enough to consume all of your available FC.
    Matt
    Donldson's Avatar
    NW Ohio
    2,912
    I believe this point needs repeating: hydrogen peroxide is a chlorine neutralizer. In a chlorine pool it will do nothing but lower your FC level, no oxidation at all. You cannot use hydrogen peroxide as a supplimental oxidizer in a chlorine pool.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
