Thread: Easy Touch relay connectors
    Dec 2014
    Riverside California
    482
    Hello All. I did a Compool to Easy Touch upgrade and few months ago and all is good with that, except for the fact that I had to re-use the 20 year+ original Compool relays. A couple of the connectors that attach the relay coil to the Easy Touch PCB, due to age and flexing have become intermittent and may or may not actuate the relays. After a good deal of searching I finally found the correct replacement connectors. A lot of searching the Molex and AMP catalogs for the connector did not bear any fruit. I finally used an eyeloop on a 2 pin header on the PCB board and found that they were JST connectors. Some more searching and found out that they are part of the JST XH line of connectors.
    Here is a link:
    https://www.pololu.com/product/1164
    I ordered some of these and they are a perfect fit. Hope this helps someone in a similar predicament.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Easy Touch relay connectors
    Good to Know Gary, thank you.
    Essential Links:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    That's a great find right there!
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Oct 2014
    Rio Rancho, NM
    114
    Thank you.
    I just posted about this and your post was linked to my question.
    Viking fiberglass Island Breeze II (16'x40'x8'); Pentair pump/filter/heater/chlorinator; IntelliTouch with iX+3; Autelis.
